Old 01-24-2003, 04:02 PM   #16
bimrpwr
Wow that sounds kind of complicated..... I have access to a welder and a plasma cutter but having the rear sleeve machined seems complicated. Do you know how much it should cost at a machine shop to have this done? For the front do you actually have to cut the sleeves down in size like actually cut down the part that is threaded?? Sorry for all the ?s but dont want to FUBAR anything.
Madison
1987 BMW 325 IS
"The Ultimate Driving Machine"
bimrpwr is offline   Reply With Quote
Old 01-24-2003, 04:08 PM   #17
MOTRONIX
MOTRONIX's Avatar
hi steve
youwill need to cut down the sleeve itself. and for the rear you will need access to a lathe.
this is the easiest way. talk to randy about machine work.i hear he is not bad at machining
dave
MOTRONIX is offline   Reply With Quote
Old 01-25-2003, 11:10 PM   #18
e30m52power
e30m52power's Avatar
Just out of curiosity what size struts do the e36 use? Are they 51mm like the e30's?
e30m52power is offline   Reply With Quote
Old 01-26-2003, 02:30 PM   #19
bimrpwr
Randy check your PM
Madison
1987 BMW 325 IS
Old 01-28-2003, 11:11 PM   #20
MatyBMW
MatyBMW's Avatar
Send a message via AIM to MatyBMW Send a message via Yahoo to MatyBMW
sketchy
This OBX installation procedure sounds a little sketchy.
I think I'd rather go with
Billstein or Koni shocks \ struts
and
Eibach or H&R springs
--MatyBMW
MatyBMW is offline   Reply With Quote
Old 01-29-2003, 12:20 AM   #21
Jon@Bimmersport
Jon@Bimmersport's Avatar
Originally posted by djcontra
yeah coilovers can be crazy expensive, but they're worth the money as well if you want a solid feeling ride.
I was lucky enough to find some for under $1000 (but they were stolen hence the price. They were regularly $3500 CDN new)
adam..sometimes i wonder...are you constantly blazing? lol first that pic u posted, and now about stolen parts....you really wanna get caught DONT u! hahaha..
Authorized Ontario dealer for Active Autowerke|VF-Engineering|AFE|Bilstein Suspension|H&R Suspension|KW suspension|Brembo Brake Systems| Stoptech| - Call us for the best pricing
Old 03-12-2003, 04:14 AM   #22
808BMW
Sorry to bring up a semi-old topic, but wanted to ask a few Q's:
For the front, since the OBX coilovers offer so much adjustment, do you NEED to cut the front perches? It sounds like if you cut the perch and slam it all the way down, your tire would rub on the spring perch. Can't you just slam it down all the way on the stock perch?
For the back, the sleeve is just a solid can type thing with a flat end right? So you just bore out a little pocket in the middle for the small nub on the lower control arm to fit in it perfectly... right?
808BMW is offline   Reply With Quote
Old 03-12-2003, 03:34 PM   #23
bimrpwr
Correct.
1987 BMW 325 IS
Old 03-26-2003, 01:57 AM   #24
msifashion
If I just didnt cut the front perches how low would they be able to go? I just want about a 2 inch drop from stock, not the whole 4 inches.
msifashion is offline   Reply With Quote
Old 03-26-2003, 01:56 PM   #25
Luke WL.
complicated post.... well since you guys know what your talking about, just wondering if i get bilstein coilover ( i already have ebiach pro springs) will i have to weld anything? (im gunna get a shop to do em cuz i cant) or are they just bolt on?
Luke WL. is offline   Reply With Quote
