03-11-2008, 10:58 PM
#1
Car: 2k1 GTI Turbo
EDUCATE ME! the dreaded "what swap" question
So, I've done my research...I have a couple of options.
Car is a 1985 325e 2.7 ETA engine...woopie.
SO...these are my options...
there is a low mileage ETA bottom end, with a stroked 2.7 "I" head thats available...as far as I know, this essentially would be more or less a direct bolt-in? please correct me if I'm wrong
Otherwise, the consideration of either a M30 or M50 swap...but than i'm looking at swapping trannies, ECU, wireharness etcetc....
Correct me if I"m wrong, please understand i'm trying to get my information straight...I have done my searches on r3vlimed...however am looking for consice answers.
On average...what has the cost of a M50 swap run roughly?
I am looking to get this done prior to springtime...
Thanks for your patience and understanding
03-12-2008, 12:38 PM
#2
Car: 2k1 GTI Turbo
really?
nobody knows?
03-12-2008, 01:15 PM
#3
Car: 87 325is
nope. because it all comes down to what exactly you want, how much you are willing to spend, and how much are you gonna do yourself. since you have the eta, maybe you can go in the stroker direction.
personally, if i had the money i would go with either a 24v or big six swap
03-12-2008, 02:25 PM
#4
Car: E34 525i
There is no such thing as "stoked 2.7 "I" head" but and ETA bottom end with "I" head would be a direct bolt in.
That depends, are you doing the swap or getting a shop to do it for you? are you gonna make the mounts yourself or buy them? and wither you buy the parts for doing the swap or buy a donor car.
A lot of guys who are considering power upgrades don't really know what they want, you need to set goals on exactly how much power you want and what purpose you want it to serve, track, drag or just a cruiser with more power. And don't forget about the budget.
03-12-2008, 02:43 PM
#5
Car: 2k1 GTI Turbo
correct-
and yes, its a ETA botton with a 'I' head- my mistake.
HaDesm- you're right...I'll probably be looking at the stroker option...eventually lean towards a boost project.
03-12-2008, 03:18 PM
#6
Car: Mississauga Transit
An i head isn't a complete bolt on, you will need your pistons notched.
03-12-2008, 06:52 PM
#7
Car: E30 M3, E30 332is & E36 M3
Certainly depends on what you want to spend, and how much you want to replace. I'd say you coudl do a basic M50 swap for $2500 if you wanted to do it cheap. I'm into my S52 swap for almost 8K, but I did everything I could think of..OBD swap, Z3 rack, transmission, Euro maf, intake, custom exhaust, new diff, driveshaft, E36 M3 brakes, 5 lug swap, ect ect....
I'd say go M30 or S50....M50 hardlly seems worht the effort for 20HP.
03-12-2008, 07:58 PM
#8
Car: 1990 E30 M3
I heard doing a chip on a eta can add up to 24 HP and around 28 ft lbs of torque. It'll coast you a couple hundred and might hold you over for a while.
Just putting a "i" head on a eta bottom end will get you around 30-40 WHP with a stand alone engine management.
What you have to ask yourself is how much power do you want and how much do you want to spend.
If you rebuild your m20 with Super eta pistons you could probably get around 160 WHP. It would probably cost you around 1500.
I'm running a eta bottom end with "i" head and it cost me around 700, and gave me around 140 WHP but I did it to boost it.
Here is how my 85 eta accelerates with 140 WHP to give you an idea
http://www.youtube.com/watch?v=hy0s1ayxiiU
Not really that quick, kinda slow but it's still fun. For me a stock eta wasn't really that much fun but I hear adding a chip really makes a world of difference.
If you do a swap you should probably only bother if you want more than 180 WHP and have more than 2-3gs to spend on it.
Good luck
Oh ya just wanted to add that you won't have to notch the pistons if you go with the eta bottom end and "i" head. I'm not sure about going with a Super eta bottom end, Dgmorr would probably be the best guy to answer that.
03-12-2008, 09:23 PM
#9
Car: 2k1 GTI Turbo
Aveman- your setup (eta bottom with "I" head) is exactly what I'll end up doing-
after speaking to some local E30'ers here..it'd be the best back for the buck...so it seems...
(btw what exhaust are you running? sounds badass!)
have access to a low(er) KM'd ETA bottom with "I" head, thats been rebuilt for the puposes of boosting...
this would also "as far as I know" a direct bolt up to my tranny...85 eta same as 87 eta? anyone confirm?
anyhow-
heres some better pics of the '85 I picked up yesterday- haven't touched ot or done anything to it.......yet.
The rust...probably will just get new fender.
Sunroof
03-13-2008, 12:11 AM
#10
Car: 1990 E30 M3
Nice find looks really clean. I bought the exhaust off another member, it's nothing special just a 2.25" from the manifolds back. Running a Magnaflow twin tip muffler. I'll be putting it up for sale soon for cheap so I can start bolting up the turbo setup.
03-13-2008, 12:49 AM
#11
Car: 87 325is
looks better in these pics. thats a clean e30.. at least the rust spots are on the fenders
03-13-2008, 12:07 PM
#12
Car: e30,325isx2,320i,535
How hard is it to swap in a complete 325is motor from a 87.?
03-13-2008, 12:48 PM
#13
Car: 330ci SC, M5 Touring
If you are looking for best Hp for the $$$, you cant beat the big 6 M30. You get S50 power for about 1/4 of the price. The engine is bulitproof, easy to find, ready to swap in E30 (dont have to look for oil pan like m50/s50 etc). With a few small mods like chip, intake, exhaust and you have even more power and tons of torque...
03-13-2008, 02:21 PM
#14
Car: 2k1 GTI Turbo
unsure...
so far, I have my eye on a couple of engines
1st engine is the one that Raf from Turbo-Ready has (eta bottom with "i" head) which more or less would be a direct bolt on...
2nd, is infact Rafaels old engine from his boosted 87 325is...with prepped oil outlet source allready prefabed for turbo application
Eurostyle-
The M30 would require a whole tranny swap, source a 528 rad, swap out engine harness etc etc etc etc etc...?
or am I completely out to lunch on that thought...
not too concerned about HP...torque is where all the fun is at...
also trying to maintain a descent daily driver status (for the summer)
03-14-2008, 06:22 PM
#15
Originally Posted by Wingking
Eurostyle-
And for a turbo motor you have to get intercooler, tubing, full exhaust, blow off valve, cooler/oil lines, boost gauge, engine managment, tons of time and effort for tuning...You have to be a lot more carefull when using it (eg; dont shut it off too soon, or get turbo timer...) and chances are it still wont be as reliable as a NA car.
If torque is what you want, you know what they say; there is no replacement for displacement!!!
