Old 03-10-2008, 05:39 PM   #1
Flickering HID, HELP PLEASE!
My setup:
-Retrofitted E46 projectors, using Hella Gen4 Ballasts with separate igniters
-Soldered the ballasts' wires to female 9006 plugs, which then hookup to the male 9006 on my car to power the low beams
-The soldering is properly sealed and the power/ground are not in contact so there shouldn't be a short over there
The problem:
-Driver's side low beam stopped working.
-Initially thought it was the ballast/igniter, so I replaced it and still wouldn't work
-Turns out the fuses for both the low beam and high beam on the driver side blew
-Replaced fuses, high beam works and now the low-beam fires up but the bulb is at like half intensity and keeps flickering, then eventually turns off.
-Swapped bulbs, and the problem still persists on the driver's side.
WTF is going on? I'm guessing its the ballast but I just had it replaced...
Old 03-11-2008, 12:07 AM   #2
Seyar
Seyar's Avatar
don't mean to jack your thread but i have the same issue if some one can help us out that would be great.
Seyar is offline   Reply With Quote
Old 03-11-2008, 12:18 AM   #3
anuk, bro i'm happy to look at it for you
Old 03-11-2008, 12:46 AM   #4
kenmar
Read this thread, it may answer a lot of questions: http://faqlight.carpassion.info/headlamp-harness.html
Initially, I did not use a wiring harness relay for my HIDs and I could occasionally hear loud crackling noises in my stereo when I turned on the HIDs. After installing the relay+diode harness, no more strange noises thru my stereo.
Old 03-11-2008, 12:43 PM   #5
^^lot of good info. I wouldn't agree with every single thing written there, but a most of it is dead on.
Old 03-11-2008, 04:05 PM   #6
Dr. Flyview
"Mint"
Dr. Flyview's Avatar
So you recommend we buy a wiring harness for HID systems b/c the load is too high initially??
1998 BMW 328is - summer
1993 BMW 525i - sold
1994 BMW 325i - sold
1992 BMW 325i - gone
sold
Old 03-12-2008, 04:58 PM   #7
UltimateDriv
Bimmerhead
UltimateDriv's Avatar
Send a message via AIM to UltimateDriv Send a message via Yahoo to UltimateDriv
just make one, its simple. and all you need is the wires and a relay.
UltimateDriv is offline   Reply With Quote
Old 03-12-2008, 08:29 PM   #8
well, if you get your kits from me, they come with a relay free of charge. You dont NEED a relay, its preventative.
anuk, swing by my place, we can test it.
Old 03-12-2008, 11:14 PM   #9
kenmar
My initial stab at a wiring harness was with just a relay, but the Bosch foglight relay that I used seemed to cause scary sounding kickback into my electrical system that I could hear in my stereo (loud popping/crackling noises). This happened when I turned on the HIDs. I finally eliminated that by installing a diode into the circuit as described in that link I posted above.
Old 03-27-2008, 03:14 PM   #10
Seyar
Seyar's Avatar
did you figure out what it was?
Old 03-27-2008, 03:44 PM   #11
Yeah, busted ballast.
Old 03-27-2008, 05:23 PM   #12
UltimateDriv
Bimmerhead
im no expert..but i was told that you do need a relay for E36's because the stock wiring cant handle it. (bimmerforums.com)
actually, i tried to hhok up my hid kit using my stock wiring and it didnt work.
i wired it myself with a relay, and it was good to go.
Old 03-27-2008, 05:46 PM   #13
I've been using HID kits on my E36 for almost 3yrs now without a relay. No problems whatsoever.
