Old 03-03-2008, 09:06 PM   #1
Spoose
Too Much Heat
Okay, so a few days ago, I notice that the heat was not working too well. I turned it up all the way and not too much heat. Also, I should mention that the dial on the centre vent which controls the heat/cool is broken. Car told me coolant was low, so I filled it up.
Now, at the lowest setting, I get heat. Even if I turn on the AC I get hot air out of the vents. If I turn it to the hottest setting, I could fry an egg on my vents.
Did I blow my thermostat.... What could be wrong?
Current Rides: 964 C2
Past Rides: 94 318is, 97 M3, 01 C2 Cab, 02 330ci, 06 323i, 05 330cic M Sport, 02 M3
Spoose is offline   Reply With Quote
Old 03-04-2008, 07:53 AM   #2
alpine323
alpine323's Avatar
Does the air blow cold when you are stopped?
alpine323 is offline   Reply With Quote
Old 03-04-2008, 09:09 AM   #3
Spoose
Forgot to check that, I'll see today.
Old 03-04-2008, 09:15 PM   #4
Spoose
No, does not blow cold when stopped. Constant heat? Any ideas?
Old 03-05-2008, 02:03 PM   #5
Dr. Flyview
Formerly Flav_cool
Dr. Flyview's Avatar
Send a message via MSN to Dr. Flyview
THere's your problem. For some reason this is like a master switch for the face vents and yours is stuck on hot.
Do you have the same constant heat problem for let's say, the window vents? I'll bet you don't.
If it's the thermostat your car will either overheat (stuck closed) or not warm up enough (especially when idling when driving through very cold air) and you won't have heat...
1998 BMW 328is - summer
1994 BMW 325i - daily
1992 BMW 325i - totaled
sold
Dr. Flyview is online now   Reply With Quote
Old 03-05-2008, 08:59 PM   #6
Spoose
thanks Flav, I'll check it tomorrow. How do I fix it?
Old 03-05-2008, 09:03 PM   #7
Dr. Flyview
Formerly Flav_cool
I'm guessing replace that center face vent.
sold
