Old 02-27-2008, 05:51 PM   #1
El Gato Liso
El Gato Liso's Avatar
the new e30 audio electrical mess....help plz
i NEED to have music in my car. but not needing it to the point of entire overhauls with diesed sound systems amps and subwoofers.
basically. i just want the headunit to all 4 speakers...if that is possible.
the car doesnt have the stock amp installed..it was taken out. it had aftermarket wiring done with a cassette player attached to an 8 disc cd changer.
nd the previous owner wants his audio back so i had to strip everything out.
if the wiring were kept stock than that wouldnt be an issue at all, since i did it fine in the previous e30.
SO
my picture attached will show u my idea in my head.
is that possible? just DIRECT connection to the speakers from the head unit?
***E30 part out to come. Gimme a PM for any inquiries!***
Old 02-27-2008, 07:00 PM   #2
yea thats how stereo systems usually work.
Weather or not your car already has wires from the deck to each speaker, who knows what the previous is, hopefully the wires are already there.
Worst case you would have to re-run the wires to each speaker.
You power, ground and power antena wires should still be there.
Dare I squeeze
Old 02-28-2008, 09:18 AM   #3
tominizer
............depends on the head unit. IF it has a built in amp with front and rear speaker outputs, you are golden. Running new speaker wire from the head unit to your speakers (totally recommended on cars this old) is a snap.
Cheers
Old 02-29-2008, 10:35 AM   #4
El Gato Liso
i forgot about this thread
but great thanks tom and tdot
the wiring shouldnt be that hard at all. i should be able to use the STOCK front and rear speakers thgouh right from the headunit directly to those stock speakers.?
