Old 02-21-2008, 09:50 PM   #1
slimjim
Almost Sideways
defroster not working
ok, this is getting annoying now, my windows are always fogged up and i cant see shit when backing up etc... my defroster does not work, is this common problem in e30's? because my buddies doesnt work aswell... any suggestions?
thanks, jake.
Old 02-21-2008, 10:07 PM   #2
check fuses, check the switch, then check for power at the rear glass.
If you determine you have power, then you'll most likely have to replace the rear glass.
Old 02-21-2008, 10:14 PM   #3
e30_kid89
The Afro-stig
e30_kid89's Avatar
I have a rear glass, $40. defrosters worked mint.
Old 02-22-2008, 10:29 AM   #4
supernaught
supernaught's Avatar
all windows or just rear? blower/heat not working?
Old 02-22-2008, 03:40 PM   #5
slimjim
Almost Sideways
just my rear.
Old 02-25-2008, 04:28 PM   #6
bimmer1989
bimmer1989's Avatar
check
I had almost the same problem there was water in my trunk and when i turned my heater on the car would heat up and all the humidity caused by the water would condence on my windows so if your windows are fogging up bad enough that you cannot see out of it there is probably water some were in the car.
bimmer1989 is offline   Reply With Quote
