Old 02-21-2008, 05:01 AM   #1
scottyp
dungeon master
scottyp's Avatar
Toe In Problem
So i just picked up a '88 325is and it has h&r race springs and bilstein shocks i drove it back from california to toronto, ontario and by the time i got to indianapolis i needed to buy new tires on the rear of the car. When i started my journey the tires had at least 85% life left on them and the original owner had not had them long. they look like they have alot of toe in and i do not know how to fix this, yes i have used the search button. also when i go past 50 mph the wheel has a vibration and im pretty sure it is coming from the rear. when i got new tires the tech told me that its a simple fix to get more toe out but he didnt have the part available right away. help????
scottyp is offline   Reply With Quote
Old 02-21-2008, 08:38 AM   #2
FuryriderX
cra.iX.y
FuryriderX's Avatar
no e30's had adjustable rear toe from the factory. the only way to adjust it is with eccentric bushings or slotted trailing arm mounts.
that being said, theres no way you should be going through tires like that, even excessively lowered. get it up on an alignment rack and see what the problem is. maybe the PO installed one of those parts, and they shifted around a bit.
Old 02-21-2008, 12:19 PM   #3
+1
Theres no way camber can wear things out that fast, definitely a toe problem. Something bent like a trailing arm or something? Bushings worn out beyond belief?? I doubt it though... That is REDE30iS' car from R3V right? looked to be in good shape... Definitely prop it up on a hoist and check it out underneath.
Old 02-21-2008, 12:51 PM   #4
e30_kid89
The Afro-stig
e30_kid89's Avatar
Congrats on the buy, clean car.
This is your car right??
I would suggest getting it up on a hoist and taking a look at it, and following it up with an allignment to get some numbers. From there you can know what the problem is and take w/e actions needed it fix it.
Btw how was the drive
Old 02-21-2008, 01:26 PM   #5
scottyp
dungeon master
scottyp's Avatar
yes isnt she beautiful funny thing is it had the rear trailing arms and a whack of suspension work done about two months ago. the rear tires look like this / \ from behind though. and i just noticed the left rear side sits waaaay lower then the right. ugh..
Old 02-21-2008, 09:41 PM   #6
hadesm5
hadesm5's Avatar
dude thats one cleaaaaan e30.... sick color!
hadesm5 is offline   Reply With Quote
Old 02-21-2008, 10:00 PM   #7
slimjim
Almost Sideways
was the car hit? bent control arm? id suggest worn out bushing maybe? you said the car sits lower on one side? maybe he was hit/ slid into curb and bent the controle arm causing the car to sit to one side?...but thats just me talkin
edit* new trailing arm huh? maybe it was hit and its all bent where the trailing arm connects to body?
p.s dam, that is one nice looking car, how much?
Old 02-21-2008, 11:51 PM   #8
scottyp
dungeon master
scottyp's Avatar
http://www.e30tech.com/forum/showthread.php?t=51966
That is the original ad, lets just say i got it for a fair price
thanks for the input guys, i took the car to a local bmw mechanic and he's taking a look at it, i thought it was sitting alot lower on one side but turns out my driveway has an invisible dip in it that made one side sit higher, ha. you honestly cant see it unless the car is in it.
Old 02-22-2008, 12:03 AM   #9
hadesm5
hadesm5's Avatar
nice i thought it was calypso red from that pic.
