Old 02-20-2008, 10:52 AM   #1
uncle ben
uncle ben's Avatar
Where to plug the angel eyes on Depo's?
Hi, I just received my Depo headlights with chromium angel eyes, and I just don't know how to make the angel eyes work..
On the back of the light, there's the usual 2 big wires for each bulb, and one little simple grey wire. Can anyone help me?
Thanks!
uncle ben is offline   Reply With Quote
Old 02-20-2008, 11:06 AM   #2
vadim321go
vadim321go's Avatar
you should have a plug and play connector which has 4 pins to which u connect the wires. the angel eye wire is white. power is red. ground is black. and green i forgot. also in order to make the angel eyes work u need to splice them into the corner lights so they get power
Proud owner of a 95 325i
Old 02-20-2008, 11:16 AM   #3
uncle ben
uncle ben's Avatar
look, I took a quick snapshot, hope you can see..
I think all the wires are already connected as they should, I just need to plug the grey one in a corner light, but I really don't see how I can do that..
Alpine E36 M3
Old 02-20-2008, 11:24 AM   #4
vadim321go
vadim321go's Avatar
take a picture of the back of the lights, where the oval is with the 4 prongs coming out
also where did u get these from, and were the angel eyes pre installed?
Old 02-20-2008, 11:31 AM   #5
uncle ben
uncle ben's Avatar
Yupp, the angel eyes were pre-installed.Baught them from bavtoys, but they came from umnitza.
By mtl_golf
Alpine E36 M3
Old 02-20-2008, 11:41 AM   #6
vadim321go
vadim321go's Avatar
ok so ur pretty much set. so teh white and black connectors plug into the existing ones, just match up the grooves to see what goes where. that white wire you splice into the corner light to give the AE's power.
Old 02-20-2008, 11:44 AM   #7
uncle ben
uncle ben's Avatar
what do you mean by "splicing"? (I'm french))
I've looked into the corner lights, and there's nowhere I can plug it..
Alpine E36 M3
Old 02-20-2008, 12:22 PM   #8
NateoriouS
Nateorious C.A.G
NateoriouS's Avatar
^^ you need to strip a portion of the white wire and strip a portion of your corner lights wire, and attach ("splice") them together so that the white wire get's power from that, not the plug
'88 E30 325i sold
'88 E30 325i 2.7 stroker sold
'95 E36 318i sold
'94 E36 325ic Cabriolet sold
'87 Mazda RX-7 Turbo II sold
'96 E36 328i Cabriolet - sold
'92 Mazda Miata Black Nardi Edition sold
'98 E36 M3 Cabriolet -
"Float like a Cadillac, Sting like a BEAMER" ... ... Lightning McQueen
NateoriouS is offline   Reply With Quote
Old 02-20-2008, 12:25 PM   #9
uncle ben
uncle ben's Avatar
thing that bugs me is that it's a simple wire, not a dual with positive and negative.
Alpine E36 M3
Old 02-20-2008, 03:09 PM   #10
uncle ben
uncle ben's Avatar
anyone have a picture of the AE connection to the corner light?
Alpine E36 M3
Old 02-20-2008, 05:31 PM   #11
$500bimmer
the ground is common in the headlight.....dont worry about the ground. when you plug the connectors in...you'll have a ground.
Old 02-20-2008, 06:23 PM   #12
uncle ben
uncle ben's Avatar
so the current dosen't need to go in the AE one way and go out the other?
(like a normal home lamp)
it's a single core electric wire..
Alpine E36 M3
Old 02-20-2008, 07:04 PM   #13
98Dinan3
98Dinan3's Avatar
That's right. There will be 3 wires going to the corner. A ground, power for the corner light, and power for the signal light. You want to tap into the power for the corners. It will supply constant power to the AEs while your lights are on. If you tap into the wrong one, they will blink along with your flashers.
Old 02-20-2008, 07:15 PM   #14
R.S.C
Imaginary Player
R.S.C's Avatar
The AE is already grounded, just need to give it power now. You get the power from the side blinker wires
Driver Side Blinker = Purple
Passager Side Blinker= Yellow
Heres a pic I stole to show you:
In this pic the red wire is the AE power
Yamaha R6 + Alpine White F30 + Techno Violet e36
R.S.C is offline   Reply With Quote
Old 02-20-2008, 07:36 PM   #15
uncle ben
uncle ben's Avatar
will the day lights still work if I pluf the AE's?
Alpine E36 M3
