Old 01-21-2003, 06:15 PM   #1
3 Series Freak
e30 eta Performance Camshaft
Brand new in box e30 eta performance cam from Cat Cams in Belguim. Asking $450 give me a call 416-418-5260
Paul
3 Series Freak is offline   Reply With Quote
Old 01-21-2003, 06:40 PM   #2
e30m52power
e30m52power's Avatar
What duration is it?
e30m52power is offline   Reply With Quote
Old 01-21-2003, 08:58 PM   #3
3 Series Freak
Cam specs
sorry about that. here are the specs
Valve clearance Inlet: 0.25 mm Exhaust: 0.25 mm
Valve Lift Inlet: 10.50 mm Exhaust: 10.50 mm
Rocker arm ratio: 1.5/1
Cam Lift Inlet: 7.00 mm Exhaust: 7.00 mm
Valve Timing: 272 degrees
I can also get the adjustable cam gear from cat cams as well. Last checked it was $275
thanks
paul
Old 01-21-2003, 09:49 PM   #4
SpoolinS6
SpoolinS6's Avatar
what motor are they for m10"s
eh u still interested in the compressor tanK if so pm me!
1995 Audi S6
HI BOOST
Old 01-21-2003, 10:10 PM   #5
3 Series Freak
Re: Cam
The cam is for an M20 I don't know if it would fit an m10. I will pm you on that tank. Busy week.
thanks
paul
Old 01-21-2003, 10:19 PM   #6
3 Series Freak
Re: Cam
To be more accurate the cam is for an e30 eta 2.7L 6 cylinder hope that helps
thanks
paul
Old 01-25-2003, 01:06 PM   #7
Sim_Sima
The Sims
Sim_Sima's Avatar
Would that cam of yours, fit an m20 2.5 litre engine??
Sim_Sima is offline   Reply With Quote
Old 01-25-2003, 02:10 PM   #8
punnzzells
punnzzells's Avatar
Send a message via MSN to punnzzells Send a message via Yahoo to punnzzells
if anyone needs cat cam gears to go with that cam, i have some (2) cat cam gears... i posted earlier and no one wanted them, but they would work awesome with that cam. i will sell em cheap.
mike.
punnzzells is offline   Reply With Quote
Old 01-25-2003, 02:19 PM   #9
The Sly
The Sly's Avatar
PM me on this stuff Please
The Sly is offline   Reply With Quote
