Old 01-21-2003, 05:37 AM   #1
Indecisive
Send a message via AIM to Indecisive
Help wif Cruise Control
I have a '88 325i 4 dr and I can't figure out for the life of me how to work the damnned cruise control....
I go to the speed I want, push the stick forward and hold it there for a second or two and it should be done rite? and then tap forward to go faster, tab towards me to slow down, down to turn it off and up to resume rite???
I do that...sometimes it engages and if it does..it goes for about 5 seconds and cuts out. I(well rather my sister) brought it into the servicing place a few months back and they said it was working fine and that I dunno how to use it or something...(my genius sister didnt' ask how to work it..and it's too far outta my way to go there again.)
I still haven't been able to figure out how to work it so can somebody please help me out? and yes..I've read my manual and stuff...I thot I was doing it right but apparently not.
thanks
"you don't realize how much of a luxury cup holders are until you don't have em" ~Indecisive
Indecisive is offline   Reply With Quote
Old 01-21-2003, 06:52 AM   #2
FatDaddyBMW
Send a message via AIM to FatDaddyBMW
Re: Help wif Cruise Control
thanks
On my e28, it's slightly different. I would imagine your e30 is the same as my e28:
Pushing it away is to set and accelerate, just like you thought. But, pulling it toward you is resume, and up or down is to cut it off.
Hope this helps,
Brad "Shifty" Couvillon
'87 528e <--- Mark D'Sylva chip, 3.46 diff, 5-speed conversion, Bav Auto / Bilstein Sport
FatDaddyBMW is offline   Reply With Quote
Old 01-21-2003, 12:05 PM   #3
I dont know how to work mine. i dfoubtr it even works. Its 5 spd. i thought 5 spd dont have cruize controls.
Old 01-21-2003, 02:48 PM   #4
FatDaddyBMW
5-speed does have cruise control. There's a little bit of wiring I had to do to get the cruise to work when I did the auto-to-manual swap. It should work, though. You might have a problem with your clutch or brake switch or the ground.
If the clutch switch isn't working, the cruise control brain will think the clutch pedal is pressed and cut off the cruise. I'd get under there and look to see if the clutch switch is being pressed all the way in when the pedal isn't being touched. Here's a pic of the clutch switch.
Actually, it's the brake switch that I have highlighted in green, but look to the left of it and you'll see the clutch switch. All you have to do is adjust the two nuts on the clutch switch so that the button is pressed whenever the clutch isn't being pressed.
You'll see the brake switch highlighted in green. The '87 brake switch is different, and the pedal box I had was from an '85, so I had to fab up my own connectors. Anyway, here's the pic:
Old 01-21-2003, 04:21 PM   #5
SickFinga
SickFinga's Avatar
5 spd does have cruize control, I have it on my car.
For me it works same as on your E28 Brad, I push on it outwards it engages, push it up or down it disengages.
Old 01-21-2003, 05:23 PM   #6
Indecisive
well mine's a 4 spd auto if that makes any difference. my dad might've adjusted the throttle position though...so might that be it?...but that shouldnt' affect anything if I'm still driving should it?
Old 01-21-2003, 06:10 PM   #7
FatDaddyBMW
My car used to be a 4-speed auto (back in November), so I have experience with this, too.
It could still be the brake switch. Look at the picture above, and you'll see what a pre-87 brake switch looks like. The '87 and later looks a little different, but it's in the same place. The problem is that it can get out of adjustment, so the button won't be pressed when the brake pedal is at rest. If this happens, the cruise won't work, and the brake lights will stay on.
If your brake lights don't stay on, then it's not the brake switch.
A problem I was having with my auto was that the shifter wasn't adjusted very well. I could press forward on the shifter when in Drive and make the N light up on the light bar in the instrument cluster, but it wouldn't engage Neutral. This would cause the cruise to cut off, too.
A third thing to check is your fuse box. You might've blown a fuse. If I remember correctly, the cruise control is fused, so there could be a blown fuse in the fuse box.
Also, check the cruise control box itself. It might not even be there, or it might just have a loose connection. Unplug and replug everything and make sure the connectors are tight.
If you still have problems, then you probably have either a bad cruise control stalk or a bad cruise control brain.
Hope this helps!
Old 01-22-2003, 03:21 AM   #8
Indecisive
thank you so much. this is probably what's happening.
I put my car in drive and it's halfway between neutral and drive and my reverse lights come on in neutral...ai. so this is probably what's making it cut out?
how did you fix this problem??
it's not my brakes cuz my brake lights dont' stay on.
Old 01-22-2003, 04:29 AM   #9
FatDaddyBMW
Converted to a manual. Heh heh heh
Actually, there's a way to adjust the shifter so that it doesn't do that. I'm not exactly sure how, though. Do you have a Bentley manual? It may be in there.
Sorry I couldn't be of much more help.
Old 01-22-2003, 05:38 AM   #10
Indecisive
lols well I've posted this on a few other boards so I'll wait for replies to come in(if they do...).
thanks a whole bunch..you've been a lot of help..now I have an idea of what's wrong with it. thanks again.
