Old 01-24-2008, 01:47 PM   #1
Mickey Knox
18 inch ultraleggera stagger set for 650 buck
guys,
i found these on ebay:
http://cgi.ebay.com/ebaymotors/18-OZ...spagenameZWDVW
they are half the price of tirerack for the staggered set, question is will they fit my 93 325is. when i select them on tirerack the size they give me is:
18X8 with a 40mm offset and 18X9 with a 40mm offset
the set on ebay is
18X8 with a 34mm offset and 18X9 with a 34mm offset
will those fit? i would like to take the deal if they do
alternatively i could get some wheel spacers which should work, right?
thx
mickey
Old 01-24-2008, 02:52 PM   #2
AceOfSpades
AceOfSpades's Avatar
i'm not sure about the fitment, but i'd consider other wheels first
AceOfSpades is offline   Reply With Quote
Old 01-24-2008, 04:39 PM   #3
They will fit fine without spacers. Don't go wider than 225/40/18 though (even in the back).
Old 01-24-2008, 05:20 PM   #4
Mickey Knox
ty jay,
i actually looked again, the 18X9 for the rear are the same offset as tirerack suggested (40mm) on tirerack they recommend 245/35-18 for the back which i would like. are you objections based on fit or something else? 225 in the front sounds right
thx again
mickey
Old 01-24-2008, 07:32 PM   #5
The 34mm offset will make 245's a headache on an E36. But you're more than welcome to try, just roll the crap outta the fenders and make sure you have a stiff suspension.
Old 01-24-2008, 11:11 PM   #6
Mickey Knox
Jay,
actually the rear 18X9's have the same offset as the set from tirerack (40mm) my car is only 1.5 inches lower on an eibach suspension.
i dunno, do the guys from tirerack go wrong usually or is it a whole different scenario even with only a 1.5 inch drop.
thx a bunch guys
mickey
Old 01-25-2008, 01:27 AM   #7
Mickey Knox
yay
just bought the wheels, we can keep discussing the tire size that should go on them, wont put them on for quiet a while
Old 01-25-2008, 11:32 AM   #8
Oh shit, I see what you mean now. Yeah you can run 245/35/18, just a minor fender roll in the rear.
Old 01-25-2008, 12:00 PM   #9
Mickey Knox
ok, let me understand something, tirerack recommends 225/40/18 on the front for the 18X8 and 245/35/18 in the rear. if i read this correctly that would make the total diameter of the whole wheel plus tire bigger in the front then in the rear?
from other forums and article i gather that 235's will still fit fine on the 18X8, so i am thinking i can put 235/35/18 front and 245/35/18 in the back.
i have found these guys
http://www.tirerack.com/tires/Compar...r=&RunFlat=All
Anyone know if they are any good? the reviews sound good and they look badass.
sorry i keep bugging you guys, just dont know much about tires and wheels
Sigh, another 12 weeks till i can put them on.
Old 01-25-2008, 03:42 PM   #10
Manimillion
Photographer
The radius will only have .1 of an inch difference...
225/40/18 means, the sidewall is 40% of 225mm,
245/35/18 means that the sidewall is 35% of 245mm
The number by itself doens't explain anything, this is a common misconception among a lot of people.
Manimillion is offline   Reply With Quote
Old 01-26-2008, 12:16 PM   #11
What Mani said, the 35 and 40 are ratios, not fixed measurements.
I can suggest tires for you, rank these attributes from highest to lowest:
Dry traction
Wet traction
Hydroplaning resistance
Handling
Noise
Ride
Treadwear
Price
Old 01-26-2008, 03:54 PM   #12
JUS_CRZN
My other car's a jet.
JUS_CRZN's Avatar
Very good price, 1 paid $340 a wheel for my 17's.
JUS_CRZN
JUS_CRZN is offline   Reply With Quote
Old 01-28-2008, 09:55 AM   #13
Mickey Knox
Dry traction 5
Wet traction 7
Hydroplaning resistance 6
Handling 8
Noise 1
Ride 4
Treadwear 3
Price 2
thx jay,
i have put numbers next to it, 8 being the most important
Old 01-28-2008, 01:25 PM   #14
Alright. With price as a fairly low priority, you have plenty of excellent options (well maybe, check Tirerack to see if they are available in your sizes).
Yokohama Advan Neova AD07
Michelin PS2
BFGoodrich KDW2
Bridgestone RE050A
Bridgestone RE-01R
Goodyear F1 GS-D3
All of these tires are the cream of the crop, and you will be very happy with any of them. Since you put handling as of utmost importance take a strong look at the AD07 and RE-01R, they are the most capable for HARD driving.
Old 01-28-2008, 01:57 PM   #15
Mickey Knox
ty all,
you guys always come through. thx a bunch.
will post pictures once the wheels are on
fly safe
mickey
