Old 01-21-2003, 10:51 PM   #16
3 Series Freak
What about this setup?
Dave,
I talking with Brad "Shifty" Couvillon on the form. He suggested a simillar setup to 325i head on a 325e bottom but not using the actual head 325i head. He suggested using the stock crank, rods, pistons and stock head. Replace the rod bearings and make sure everything is in order. If needed have the crank balanced. Have the cylinder walls honed. Use a 325i cam instead of the performance eta cam. Use325i valve springs, and 325i valves. Have the head ported for the bigger 325i valves.
Run a 325i wiring harness and 325i computer. Run a 3 bar FPR (which I will have you modify to 3.5 as suggested). Run the M30 AFM.
In your option, would this give me the higher redline and bottom end torque?
thanks again
Paul
3 Series Freak is offline   Reply With Quote
Old 01-22-2003, 01:44 AM   #17
robert79
What kinda RPM's can you get out of 325e's? What would you need to do to get 7200? 8000?
How much power does the 325e get after the 325i head swap?
"This space for rent"
robert79 is offline   Reply With Quote
Old 01-22-2003, 12:29 PM   #18
MOTRONIX
MOTRONIX's Avatar
hi paul
hi paul.
maybe im a little confused here... lol you do have an eta motor now and you have a 325i engine complete right? and you wanna swap e to i setup?
brad has great info on the performance upgrade for the eta.. go that route if you have the parts to do it. if you need some calibration and tuning let me know.
i know mikey at lakeside and we all know each other and their works and knowledge.
ill call you paul.. maybe thats a bit better...coming home at 5.30am doesnt allow help me either...
dave
MOTRONIX is offline   Reply With Quote
Old 01-22-2003, 01:47 PM   #19
3 Series Freak
Perfect!!!!!!!!!!!!!!!
Dave,
That sounds great give me a call. 416-418-5260 or 905-501-7184 ext222. By the way are still interest in that cam?
paul
