Old 02-04-2008, 12:03 AM   #1
noid
noid's Avatar
Hesitation problem
My cars having a hesitation problem. It will rev fine in neutral, however once you put it into gear it will go up untill 2000-3000 rpm then die down to then rev back up to 2000-3000 again without actually shutting off and will do this repeatedly. While this is happening i can engage the clutch and it will rev perfectly fine in neutral. Sometimes after driving for a bit it'll go away. Iv also realized that sometimes if open the coolant res cap air will rush out and if i bleed the coolant at the same time the problem will go away. The coolant light is also on in the car and after replacing the coolant it still hasn't shut off. If left idleing for to long it will also heat up to the red, but as soon as you start driving it will go back to the middle and stay there (airflow im guessing cools it down). What could this be?
Old 02-04-2008, 10:36 AM   #2
supernaught
supernaught's Avatar
thermostat is not working
You have a coolant leak(im guessing at the thermostat housing)
Check you oil for milky colour, could this be a bad head gasket?
Old 02-04-2008, 01:01 PM   #3
Shoes R
Shoes R
Shoes R's Avatar
could also be your water pump
Shoes R is offline   Reply With Quote
Old 02-04-2008, 01:13 PM   #4
could be anything, take it to someone who knows what they are doing.
You've mentioned like 4 or 5 different problems, all of which could be a number of different things. Impossible to dianose online with the info you provided without guessing
Old 02-04-2008, 04:36 PM   #5
noid
noid's Avatar
I just changed it a couple days ago and it was clearly black with no discoloration.
Old 02-04-2008, 10:38 PM   #6
slimjim
Almost Sideways
when was the last time you changed ur fuel filter?
Old 02-04-2008, 11:07 PM   #7
noid
noid's Avatar
like a week ago
Old 02-04-2008, 11:12 PM   #8
slimjim
Almost Sideways
i think ur rpm problem has something with fuel/ignition. i may not be as knowledgable as others on this forum but sometimes simple thinking is the way to go
these are something i think may be wrong.
vacum leak
***dirty injectors***
worn spark plugs/ incorrect gap
low fuel pressure (messed fuel pump)
or maybe something with the MAF
agian, as mentioned previously, its hard to diagnose over the interent, ur best bet if u have checked/replaced all these things is to take it to a shop.
Old 02-05-2008, 08:56 AM   #9
supernaught
A rebuilt head, new intake injection and exhaust, sensors, engine wiring harness, ecu and you should be close to right as rain
Old 02-05-2008, 09:02 AM   #10
supernaught
I would consider dirty injectors a big possibility.
Also, when was the last time you changed the timing belt? I'm guessing a while otherwise you should have spotted the coolant leak(probably from a failed waterpump or thermo housing)
But Damn, replace your thermostat before your head gasket does blow or worse.
