Old 01-30-2008, 05:32 PM   #1
sean_kim3
rattles
hi guys
im looking to get some subs that pounds
looking at 2 L5s something around 800 rms
but i put my friends sub in my trunk
( wit long wires running from his truck trunk to my trunk)
and he has 2 12" infinity perfects
and my car jus..rattled lke a mofo
oh and my car is 96 328i
and i hate rattles
how do i get rid of all the annoying rattles?
is htere a place that puts in deadeners in for u?
and how much wud it cost?
its mainly my inside of my trunk and my B pillars that rattle to the extreme
sean_kim3 is offline   Reply With Quote
Old 02-01-2008, 12:55 PM   #2
tominizer
Here's some ideas...... DIY-er stuff that can get you started without dumping a boat-load of money. I'm a big DIY-er guy....... to take as far as possible and when I can't make it happen anymore, then I pay someone to do the rest.
Wires...... wires rattle everywhere. Go through the trunk with a billion zip ties and make sure EVERYTHING is zip-tied down ...... EVERYWHERE. Under the rear deck in the trunk sides...... dig up everything. Wiring can even be found behind the pillar panels in some cars. Some guys go as nutz as EVERY 2 inches there's a zip tie and the wiring is wrapped in something like black hockey tape to cut down on any buzzing. Dollar store has zip ties cheapo.
Back deck....... remove it and put the box in again to test out what is rattling (after you have zip-tied everything down). If it's good, then check out the deck itself and look for loose bits. This is going to be about securing EVERYTHING down super tight.
Bumper and licence plate........ annoying to some.
Let me know how it goes..........
Tom
Current : 2013 Mini Countryman JCW, 2007 Z4M Roadster
Past: '88 E30 M3, '69 BMW 2002 Ti, 2000 328i, Audi A6 TT, BMW X5 3.0i , Audi A4, Mini Cooper Clubman S 1.8T
Old 02-01-2008, 05:16 PM   #3
sean_kim3
yeah where the rear speakers are
the whole board rattles like crraazy
and idunno how to fix that.. like put something heavy ontop? works haha
but im not gunna tie down like a 10 pound weight on it..lo
shud i screw some screwdrivers ? to hold it tight?
Old 02-01-2008, 09:54 PM   #4
hypno_nls1
hypno_nls1's Avatar
ya my back deck thing rattles liek crazy to, very interested in what you come up with
Fear Nothing. Risk Everything.
This is not your everyday, ordinary ****ing beamer!!
hypno_nls1 is offline   Reply With Quote
Old 02-02-2008, 10:52 PM   #5
tominizer
IF your back deck vibrates like crazy, gets some foam mat and install it between the deck trim and the metal deck. But it has to wedge in there tight.
Tom
Old 02-05-2008, 01:32 PM   #6
vadim321go
vadim321go's Avatar
how do u take out the rear deck?
Proud owner of a 95 325i
Old 02-05-2008, 03:49 PM   #7
Trekz
do what i did strap the sub box in the the backseat with seatbelt
Trekz is offline   Reply With Quote
Old 02-05-2008, 04:12 PM   #8
tominizer
Best job I EVER saw was the guy that cut two holes in his roof and mounted the subs ontop of his roof firing into the car............ magnets exposed to the elements. Took my vote as the Best Install Eva.
Tom
Old 02-06-2008, 05:48 PM   #9
elroy
use a sound deader like dynamat. take out the carpet from the trunk and put it down properly and then the carpet back. should take care of the rattaling.
heres an example of a trunk done with it
http://www.sillbeer.com/images/inter...-passenger.jpg
elroy is offline   Reply With Quote
Old 02-08-2008, 09:02 PM   #10
tominizer
^not.
Tom
Old 02-18-2008, 09:15 PM   #11
sean_kim3
how much do those dynamats cost
how many of those wud i have to buy to do my whole trunk???
probably a lot...rightt?
Old 02-22-2008, 02:29 PM   #12
tominizer
Dynamat alone will NOT get rid of the rattles.......... under most normal circumstances. The application of this sort of material is often misunderstood and people spend way too much dough on it................ to an installer that has no clue. There is no quick *fix* to rattles.
Tom
Old 02-22-2008, 06:01 PM   #13
thumper
^^ I agree it will be hard to get rid of all the rattles. To do a whole trunk in dynamat can get very expensive. I never heard of the zip tie technique but I am going to try that our when I install my subs.
A way that I have used before to get rid of the rattle for the licence plate and it will probaly work for the decklid too is too put like a kitchen sponge between the metal and the plate and the metal and the decklid. It will cut down on the rattling but still may not eliminate it all. Just buy packages of cheap sponges from the dollar store
Current Garage:
1984 Toyota Corolla ae86
2002 Honda CR-V Ex
1992 Bmw 325is Coupe
1989 Nissan SR20 240sx
thumper is offline   Reply With Quote
Old 02-28-2008, 10:24 AM   #14
tominizer
Zip ties cheapo at the dollar store too.
Tom
Old 03-02-2008, 02:14 AM   #15
red_e36
Ally04
hope this helps...just some things that i did..i took off the carpet with toolbox on the trunklid...and stuffed the insides with old tshirts...so the trunk lid was nice and tight...i also tighted the trunk down with the 2 knobs that control the tightness...i also put a port(3.5") on the back deck(above the rear seats)..so that it could take away some excess air..and the system sounded a lot better actually with the port...and i put rubber behind my license plate....that killed the rattling...the metal plate behind the rear seats create a lot of rattling..so i just cut mine out...no1 really sits in the back seats(seats are back in place)..and put lockwashers on the rear taillights..cuz the vibration makes them loose and they also rattle..i have no dynamat in my trunk and its just fine(with all those mods)....but that worked for me...goodluckkkkkk
red_e36 is offline   Reply With Quote
