Old 01-23-2008, 12:51 AM   #16
FuryriderX
cra.iX.y
FuryriderX's Avatar
reeally. you mean the VR sensor on the crank wheel? did you source a new one? how much did that run you?
Old 01-23-2008, 04:30 PM   #17
SamE30e
SamE30e's Avatar
No it was the timing reference sensor on the tranny. The bottom one, the top one is the engine speed sensor.
The one on the harmonic balancer is the TDC sensor.
85 325 - Turbo M52B28.
Old 01-24-2008, 09:44 PM   #18
Ej_Red
Where exactly is that sensor located? And how did you get to diagnose it? Did you have any spark from the coil?
Ej_Red is offline   Reply With Quote
Old 01-25-2008, 01:44 AM   #19
SamE30e
SamE30e's Avatar
The sensor is located on the lower left side of the bell housing of the transmission. The engine speed sensor is the one of the top and the timing reference sensor is the one on the bottom.
I diagnosed it by starting from the engine and working my way back, plug were good, wires, coil, coil wires, ecu. Then I remembered that when I changed my clutch I saw a ****ed up sensor. I check out what the sensor did and put two and two together and got a new one. Plugged it in and it fired right up.
And no there was no spark when the sensor was broken.
