Old 01-20-2008, 01:47 PM   #1
El Gato Liso
El Gato Liso's Avatar
automatic to standard swap question...ye
well
i want to get another e30
and in the event i find one in good shape and cheap($$) but just happens to be automatic, i already have ALL the required for a manual swap (all the components clutch tranny driveshaft differential, etc) from mycurrent busted e30
im just wondering
if anyone one has done such a swap in the e30
....would it be difficult to do this swap? at home?
thanks!
R.I.P. E30
Old 01-20-2008, 01:52 PM   #2
e30_kid89
The Afro-stig
e30_kid89's Avatar
Its all pretty much a bolt-on swap, with some minor wiring required to get rid of the neutral thingy autos have. Search around i think there is a list of all the parts you need for the swap. You can do it at home but it will be a bitch removing that ugly auto box and putting in the 5spd on the floor. It is 100 percent doable though.
Old 01-20-2008, 02:02 PM   #3
I heard Zimmie likes to swap pedal boxes for fun. PM him.
Old 01-21-2008, 08:48 AM   #4
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
It's something you can do on your driveway with 4 tall jack stands and a cherry picker.
Old 01-21-2008, 09:19 AM   #5
Originally Posted by Axxe View Post
cherry picker.
cherry picker? did you pull the engine when you did your swap?
I always thought dropping the tranny alone with a jack or some help would be easier.
Old 01-21-2008, 11:08 AM   #6
talltorontoguy
Go Topless
talltorontoguy's Avatar
I've done it on my convertible on jack stands. Didn't pull the engine, instead choosing to drop the tranny from below using a floor jack. Trickiest part was the tranny bolts on top, need a very long extension and a friend. Pedal assembly is a PITA but not phsyically hard.
Join BMW Club of Canada! Click HERE
Best Engine, Bimmercruise '10 / 2nd - e30 Wild, Bimmercruise '10 / 1st - Best Cabrio, Trillium @ Tedfest '11 / 1st - e30 Wild, Bimmercruise '11 / 1st - e30 Wild, Bimmercruise '12 www.vertnation.com
talltorontoguy is offline   Reply With Quote
Old 01-21-2008, 01:23 PM   #7
328i Cab
Pulled my tranny this summer in my driveway on stands and with a floor jack. Biggest problems I ran into were the starter bolts and the top belhousing bolts. Swivel extensions/universal joints saved me on that job. Didn't take all that long either, my exhaust came off pretty easily luckily. I didn't have to do the conversion but I think the hardest part of the job will be physically removing/reinstalling the trans. Just make sure to drain them, especially the autobox before removing, it will make your life easier.
Currently: 2002 C5 Z06, 2009 335i, 2012 M796, 1976 XS650
PM me for your sidewinder (laser cut) key blank and cutting needs. Have OEM pre-ews keys and replacement shells. Can do (almost) all BMWs up to 2008!
328i Cab is offline   Reply With Quote
Old 01-21-2008, 01:39 PM   #8
talltorontoguy
Go Topless
There is a good writeup stickied on e30tech about this. Look in forum "tranmission etc".
Old 01-22-2008, 11:38 AM   #9
Axxe
Axxe's Avatar
I held the back of the engine with it. Not a mandatory item though, as the engine doesn't drop that much.
Old 01-22-2008, 07:41 PM   #10
328i Cab
can also use floor jack with wood blocks under oil pan (or scissor jack from another car like i did)
Old 01-25-2008, 02:17 PM   #11
El Gato Liso
ok nice
no need to pull out the motor!!!!!
because of the age of the car now im forced to get an 89, 90, or 91 e30 cuz insurance wont insure 88 or older
i would suppose the hardest part really is putting in the clutch master clylinder, pedals too itself
and im sure i would have to put in the differential to match the manual gear box huh
thanks afor the help
R.I.P. E30
Old 01-25-2008, 04:26 PM   #12
talltorontoguy
Go Topless
both the manual and auto's had the same diff ratios of 3.73 IIRC, so no need to swap unless you go from open to LSD etc.
Rod
Old 01-25-2008, 08:02 PM   #13
Axxe
Axxe's Avatar
Rod
3.73 auto is only in '87. '88 and older got 4.10 with an autobox.
Old 01-28-2008, 01:13 PM   #14
Dropped325i
e30experiment.com
Dropped325i's Avatar
hope this helps ya..
my 5spd swap write up and guide.
http://www.offthewallcustoms.com/Other/5spd%20swap/
89 327iT
Dropped325i is offline   Reply With Quote
