Old 01-16-2008, 04:50 PM   #1
87325I
E30 enthusiast
O2 sensor
So I had a mighty fine struggle with my first attempt at replacing my O2 sensor last night. Fack. I almost pulled a muscle...pushed, pulled, yanked on the damn wrench, but the sensor was fused to the pipe. I'm going to put it up on ramps and see if I can take a hammer to the wrench from underneath. Second attempt in the werks.
87325I is offline   Reply With Quote
Old 01-16-2008, 05:19 PM   #2
FuryriderX
cra.iX.y
FuryriderX's Avatar
get out a torch and heat the sucker up. thats the only thing that'll make it move sometimes.
Old 01-16-2008, 08:42 PM   #3
hadesm5
hadesm5's Avatar
^^ thats right. you could treat it with penetrating oil to ease things. but it won't budge with out heating it up.you dont want to damage the threads either.
hadesm5 is offline   Reply With Quote
Old 01-17-2008, 12:53 PM   #4
87325I
E30 enthusiast
Got it will break out the mini torch. Thanks!
Old 01-21-2008, 11:03 PM   #5
WillieE30
When I replaced mine I had to destroy the old one to get at the base of the sensor to remove. I heated it up and used a good size wrench with a pipe extention for leverage.....as far as the thread goes there is a tap available that normally is used for sparkplug holes that is the same as the sensor thread. I think princess auto has them if I remember correctly from my catalogue. This worked for me. Also if you do have to retap the thread be patient and make sure you retap it straight.
Good-luck........Bill
WillieE30 is offline   Reply With Quote
Old 01-23-2008, 08:33 PM   #6
Dropped325i
e30experiment.com
Dropped325i's Avatar
does anyone use an 02 socket and a breaker bar or rachet? mine has always come out easy on 3 of my exhaust setups
89 327iT
Dropped325i is offline   Reply With Quote
Old 01-24-2008, 12:09 PM   #7
87325I
E30 enthusiast
I used the mini torch, and the closed end of a wrench, slipped the chord through and came off in a snap. I looked at picking up the tool you suggested (like 20 bucks) but gave it a go first...the heat did the trick.
Cheers,
J
