Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 08-02-2011, 11:47 PM   #241
Originally Posted by jm1602 View Post
I like it. Nice and clean.
Was wondering where you went... haven't seen you on here lately Sorry we didn't chat at Mosport man, I ran over to the DDT just as you guys pulled in... I was offered a chance to take an E30 M3 for a spin over there, so I didn't want to miss out
Not that it's likely but if your driveshaft were ever to fail (u-joint or support bearing) I can see the potential for one or both of those lines to get damaged and potentially leak and if the exhaust is running down the middle that could be a bad combination.
Again, very highly unlikely as you won't have driveshaft shattering power in this car and you can hear the u-joint and bearing going bad long before they'll explode but it did cross my mind when I looked at those pictures.
Looks good though, nice fitment
To be honest, the thought crossed my mind too. However, in vintage racing, the rules specify all cars must have driveshaft loops. Its pretty much just a U bracket(or circle) that is bolted to the tunnel (can have more than one) to prevent the driveshaft from flying away in the case something were to happen. I'll be forced to put at least one in soon!
Old 08-03-2011, 12:04 AM   #242
That'll do
Old 08-09-2011, 10:53 PM   #243
Not much to update since I was at Mosport all weekend. After some discussion, it was decided that the kill switch will be mounted somewhere inside the car, and a T handle will be the solution to access it outside the car. The T handle will reside in the gutter near the passenger wiper. A cutout in the hood will need to be made, but that isn't a big deal right now.
Found an old heater box block off plate that must have been for some other car in its previous life. I trimmed the sides, drilled new holes, and installed for a test fit. I will glue it in so it is sealed after the engine bay is painted.
Took the pedal box apart today. Luckily the bushings and stuff are in decent shape, so a slosh of paint, new hardware, and it will be reinstalled.
The car is soooo motivating now that it is in one colour! Not eager to start wetsanding though...
Old 08-11-2011, 09:15 AM   #244
///Maluco
5erholic
///Maluco's Avatar
oh yeah...keep going man!
Trust me, you'll be one happy camper when you take her for a spin for the first time.
I wish you were closer because I'd love to come and help you.
..........................There will always be followers!
Bimmer Mag......................October 2010.....................Issue No. 93
///Maluco is offline   Reply With Quote
Old 08-11-2011, 11:38 PM   #245
Commmaaannnn its not that far
Built up my pedal box this afternoon. Regreased all the bushings, found some nice plated hardware to use, just have to put some grip tape on the surface of the pedals and I will be set!
Managed to install it, along with the brake system mechanism. The new clutch master came in the mail as well by coincidence today, and with a new shorter mount on the end installed just perfectly.
No more for now, as I'll be at Mosport again tomorrow! (shouldn't I be saying ????!)
Old 08-13-2011, 11:54 PM   #246
Remember these? The E21 halfshafts that were donated to this project back on page 4 lol
Anyways, now I know why I put the halfshafts off for so long... what a messy and time-consuming job! Maybe I should have just opted for the regular 2002 shafts + spacer solution lol.
This is only half of the messy warzone:
After a few hours of cleaning and a bit of painting, this is what I got:
I only put half of the shaft together before calling it quits for the evening.
Old 08-14-2011, 10:27 AM   #247
jm1602
jm1602's Avatar
What a mess
Good job on the finished product. Did you remember to put it back together with the shafts in the same orientation as they came out?
Old 08-14-2011, 09:46 PM   #248
You saw the finished product before I did? Man, you are good! lol. What a bitch to get the 2002 CV side back on. In short, I had to mix and match some parts, but it should be okay. As far as orientation goes, no they weren't marked when I got them, so I'll just put them in and hope for the best. But if anything in the rear end twists off first, my money is on the outer flange in the trailing arm...
A somewhat blurry pic that uploaded, now obvious once on the computer.
Old 08-22-2011, 11:10 PM   #249
Small stuff done lately including some rust repair for the inner left front fender area. Also got cracking on finishing the front of the fuel lines that run into the engine bay. Got some clips and stuff happening there to keep it tidy. Also installed the new grommets into the brake master so I could run the lines into there from the original reservoir. Unfortunately, I didn't have enough of the newer fancy blue soft line, so I will have to scavenge some from somebody's parts car soon enough! Also made a clutch line to connect the reservoir to the master down on the pedal box... yay stainless E36 fuel lines! Recycling FTW! LOL
Old 08-31-2011, 09:36 AM   #250
Here's some inspiration
http://www.bmw2002faq.com/component/...opic/t,362345/
Old 08-31-2011, 11:04 AM   #251
Thanks, I needed that. Last week and a bit I was too distracted with the 'new to me' cookiecutter cars
Back to inspiration...
This? LOL.
Or this? Mmhhhmmmmmmmmm
Old 08-31-2011, 04:14 PM   #252
Or this...
Old 08-31-2011, 08:31 PM   #253
^^ Definitely. Next 2002 I will do up will look a lot like some of those cars. Period correct FTW!
Old 09-01-2011, 09:20 AM   #254
cormier
cormier's Avatar
Beautiful looking rear end man! Way to go with those halfshafts
Old 09-01-2011, 02:52 PM   #255
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
More...?
Stanceiseverything.com
