Old 12-30-2017, 03:35 AM   #1
rav
New Tires Slipping
Hi,
Just got a staggered winter tire put on by Costco for my 2011 335xi mpkg.
Blizzak ws80
Rear: 255 35 18
Front: 225 40 18
When braking on the highway going at 100KM+ on a dry road that has been cleaned up or a bit of snow on it, my tires seem to slip to the right every time.
I don't see any lights (ABS) etc. coming up to indicate any issues.
Has anyone else experienced this or know why this happens? The summer staggered tires did not do this.
rav is offline   Reply With Quote
Old 12-30-2017, 09:27 AM   #2
kenmar
The WS80 is directional; I wonder if they installed some of the tires on backwards?
I did have this happen in slow snowy conditions when I paired different brands of snow tires of the same size (Michelin + Bridgestone). I have also used a slight stagger of 225 front + 235 rear without any issues.
Old 01-02-2018, 04:58 PM   #3
rav
Thanks! I confirmed they are installed correctly (arrows pointing forward). Still can't figure out why its happening...
Old 01-06-2018, 10:30 PM   #4
By "slip" do you mean pull? Sounds like alignment issues. Anytime you put new tires with old alignment you will see a difference in vehicle behavior...
Most models E30 E36 E46 E90 E92 E93 E28 E24 E34 E39 E60 E61 E32 E38 E65 E66 X3 X5 M3 M5 Z3 Z4 F30 F32 F10 F01
Old 01-08-2018, 10:36 AM   #5
rav
Thanks for the tip @Bimmer Heaven.
Will look into getting that done ASAP!
Old 03-10-2018, 07:54 PM   #6
windwagen
windwagen's Avatar
Check the tire pressure...
Is there any situation when it does NOT pull to the right? Is this HARD braking or gentle braking does this too?
E39 M5 - for Sunny Days
Old 03-21-2018, 02:16 PM   #7
rav
I can't seem to test it now as the snow has disappeared but i assume the tire pressure is good.
I checked using the iDrive console and just taking a quick glimpse of the tires. Its brand new tires from Costco.
I only see it happen when i lightly tap on breaks but at high speeds though. Never really got a chance to hit the breaks hard.
On local driving, Max 40-60km/hr i don't seem to notice this happen.
Thanks!
Old 03-21-2018, 06:07 PM   #8
windwagen
windwagen's Avatar
What - you trust the tire technician to set the correct tire pressure???? ha ha ha ha ha
Old 03-23-2018, 02:45 PM   #9
rav
haha i should def look into testing it manually. I assume the iDrive with its TPMS should be accurate??
