Old 09-27-2017, 02:16 PM   #1
MightyMat
Angry Bent Exahust Valves
So...... I just bought a 04 330ci, car shifted and drove like a dream with 150k Km on it, body in great shape. anyways, I've come to realize after driving the car a check engine light popped on, and i ran the codes and got a misfire in 4&6, swapped plugs, coils, injectors all fine, compression is fine, so i brought it my local shop and the verdict is bent exhaust valves, now, is it worth it to swap the car with a new M54 and how much would it cost me for the motor or to have this current one rebuilt and labour or should i just say screw it and try to get rid of the car. would love a second opinion, also i would love to swap the motor myself as it would save tons of money but i don't have the know how to do it.
PS: if i posted this in the wrong place i'm sorry i'm a newbie.
MightyMat is offline   Reply With Quote
Old 09-27-2017, 02:20 PM   #2
BigD
the misanthropist
BigD's Avatar
If compression is fine, so are the valves. Take it to a different shop. I recommend having Rob at Auto Evolution in Oakville look at it.
Old 09-27-2017, 10:05 PM   #3
I second that! It is impossible to have bent valves and have good compression...just NO! Sounds like they just want to sell you on something. Go to a different shop, and ask for a refund on the absurd diagnostic they just did.
Most models E30 E36 E46 E90 E92 E93 E28 E24 E34 E39 E60 E61 E32 E38 E65 E66 X3 X5 M3 M5 Z3 Z4 F30 F32 F10 F01
Old 09-28-2017, 12:07 AM   #4
jabela
Yea, they're wrong. You wouldn't have compression and it wouldn't have driven well when you tested it.
A misfire could be as simple as a bad O2 sensor or excessive carbon build up, vacuum leak (very common). Try a Seafoam treatment.
RMP Motors is not too far from you so take it there if all else fails.
www.maisonapothecare.ca
Old 09-28-2017, 09:03 AM   #5
Dinanstu
Skip the seafoam for now. Just go to RMP.
Bent exhaust valves will have 0 compression.
Old 09-28-2017, 12:11 PM   #6
MightyMat
Thanks EVERYBODY for the feedback, i appreciate it and will keep you posted!
Old 09-28-2017, 10:48 PM   #7
Trekz
What are you're compression #s? Do a cylinder leakdown test to make a
sure.
Sent from my SM-A520W using Tapatalk
Trekz is offline   Reply With Quote
Old 10-02-2017, 10:39 AM   #8
MightyMat
So Exahust valves were bent, now its just a matter of getting the head re-done or swapping the motor. Leaning more towards just getting the valves redone and going from there.
Old 10-02-2017, 11:05 AM   #9
jabela
Any idea how they were bent? Most likely an over-rev. Did you happen to let any of your friends drive it? Maybe they money-shifted.
Old 10-02-2017, 09:29 PM   #10
Dinanstu
You know right away when you over rev and fu** up the motor....ask me how I know!
Exhaust valves bent = money shift...
The cost to remove and rebuild can be pricey, I've done it, but that was for a Dinan packaged M3. You might want to source a used cylinder head?
Thoughts anyone?
Old 10-02-2017, 10:53 PM   #11
In this aluminum block, not going to last very long! Better find a low milage motor.
Tags
330ci, bent exhaust valves, m54, rebuild, swap
