Old 06-06-2016, 02:32 PM   #1
watut
E36 coolant leak
Need some help here, my 328 has a random coolant leak out of the upper rad hose. It only happens after it's been parked for a couple hours (ie. overnight). Some days won't see anything, some days a drop, some days fist sized puddle.
Radiator, Water Pump, Thermostat, Hoses are all new. Can this be a bad radiator cap?
watut is offline   Reply With Quote
Old 06-06-2016, 02:45 PM   #2
Blackedout95
Pressure test it, replace as needed.
E46
Old 06-06-2016, 10:15 PM   #3
blk3
blk3's Avatar
What he said
Old 06-06-2016, 11:36 PM   #4
watut
I have already pressure tested the system and had no leaks.
Old 06-07-2016, 11:06 AM   #5
Blackedout95
You sure? That is why you think cap?
Pressure test it and walk away for 30 minutes plus and see. Sometimes the leak is so small and in a spot that may leak high up on res. that it only occurs primarily when hot/flow. In that case get in a quiet place, add pressure and put your ear to the top of the res. and listen for a hissing.
E46
Old 06-07-2016, 12:57 PM   #6
watut
The leak isn't coming from the reservoir side, it's coming from the upper rad hose on the opposite side. If I come out in the morning (sometimes) I will see coolant on the ground and a trail of coolant down the radiator under the hose.
I had a mechanic friend pressure test it 2 weeks ago and it didn't leak. We re-seated the clamp on the hose, thinking that may be the problem. It didn't leak for 2 weeks then came back. I will try it again and leave it on for longer.
Old 06-07-2016, 01:10 PM   #7
Blackedout95
Oh ok I see, thought the res was giving issue.
Yes pressure test, leave it on longer and see if pressure drops several psi (even if no leak showing ), if so there is air escaping some where. Be sure pressure tester attachment is tight or air can escape there during test.
E46
