Old 07-11-2015, 12:13 AM   #1
South
e36 shifter linkage.
Im doing a getrag to zf swap on my 325i from a m3 and I ran into a problem.
Its like the transmission is too far away.
The shift neutral line is basically where 2,3 gear are.
I am using a 328 shifter, 325i arm, m3 rod, m3 tran.
The m3 shifter rod (part that attaches from shift rod to tran) noticed it had a bit of a bend. I am guessing this is the problem and that with a unbent rod (which will be obviously be longer) thisll solve the problem?
Such a stupid problem day. First the fork in the trany is not aligned, then i take it off put it back and the stupid slave cyclinder rod falls in.
Old 07-11-2015, 10:41 PM   #2
South
apparently, the pivot carrier is the culprit with the 325i being too long
Tags
e36 shifter linkage
