Go Back   maXbimmer Forums > Classifieds > For Sale > Drivetrain, Engines & Transmissions
Old 01-24-2018, 10:18 PM   #1
BMW-Bryon
1998-2003 540i/740i parts - mostly engine
25 posts to post to classified. I am a GMC guy now but I have these NEW BMW parts for sale. Prices as marked or package price $1200.00 These parts were to rebuild my 2003 540i Wagon but I sold it before doing the work. Mostly BMW or BMW supplier parts as per descriptions below. Parts are all new and in packages as supplied by BMW or BMW Suppliers. Located in Coquitlam, BC
Part Number Part description Qty Sell Price (Each) Sell Price (Total) Notes
33-17-1-093-008/69 Axle Carrier Mount - LEMFORDER 2 $14.98 $29.95 two per car
33-17-1-090-389/9 Axle Carrier Mount - LEMFORDER Front Differential Bushing 2 $25.34 $50.69 one per car
B2304 Battery cut off switch 1 $11.48 $11.48
11-28-7-515-865/40 Belt - Adjusting pulley assembly (INA) 1 $68.93 $68.93 Adjusting Pulley Assembly with Tensioner, Pulleys, and Base Plate for Water Pump/Alternator Belt
11-28-1-745-545/40 Belt - Drive belt tensioner (INA) 1 $36.29 $36.29
32-21-1-136-452/270 Belt - Idle Arm Bushing -CORTECO 1 $10.75 $10.75
33-21-1-227-944 bolts 12 $2.30 $27.65
34-11-1-157-041 Brake - Caliper guide pins 2 $4.61 $9.22
34-21-1-161-806 Brake Disc bolt 3 $1.13 $3.39
61-13-1-379-136 Cable holder (BMW) 1 $1.41 $1.41
13-71-1-741-097 Cap - covering cap 4 $3.16 $12.63
Plug for Engine Block Valley Cover, 4 per car
11-14-1-742-042 cap with seal - BMW 1 $67.55 $67.55 Cylinder Valley Cap, Valley Cap and Gasket for Between Cylinder Heads
11-31-1-745-406 Chain -Timing Chain Rail -Guide lower - BMW 1 $31.10 $31.10
11-31-1-741-236 Chain - Timing Chain Rail -Tensioner lower - BMW 1 $108.29 $108.29
11-31-7-531-813/36 Chain - Timing ChainTensioner 1 $35.90 $35.90
11-31-1-742-176 Clip (BMW) 1 $7.49 $7.49 Clip for Camshaft to Camshaft Timing Chain Tensioner
11-14-1-736-106 Cover - BMW 1 $32.26 $32.26 Cylinder Valley Cover, Top of Valley Cap Between Cylinder Heads
11-61-7-501-563 Cover - BMW 1 $64.51 $64.51 Intake Manifold Cover, Rear, with Non-Return Valve
11-14-1-741-532 Gasket 1 $5.18 $5.18 Engine Timing Cover Gasket
11-14-1-741-533 Gasket 1 $5.38 $5.38 Engine Timing Cover Gasket
11-53-1-731-833 Gasket 2 $8.06 $16.13 Water Accumulator Gasket
11-14-1-435-023/17 Gasket - Gasket/flange 2 $4.80 $9.60 for Vanos Solenoid
11-14-1-736-758/17 Gasket - Gasket/ring 1 $1.54 $1.54 Gasket Ring for Timing Cover 8.1 X 3.5 X 7.7 mm
11-61-1-433-328 Gasket - Profile Gasket 4 $11.71 $46.85 FUEL INDUCTION / INTAKE / MANIFOLD GASKET
11-61-1-729-727 Gasket - Profile Gasket 1 $3.84 $3.84 Throttle Housing Gasket - Throttle Housing Flange to Intake Manifold
11-61-1-729-728 Gasket - Profile Gasket 1 $3.84 $3.84 Throttle Housing Gasket - Throttle Housing Flange to Intake Manifold
11-12-0-034-105 Gasket - Valve cover gasket set - left - BMW 1 $33.41 $33.41
11-12-0-034-105 Gasket - Valve cover gasket set - left - ELRING 1 $11.71 $11.71
11-12-0-034-104 Gasket - Valve cover gasket set - right - BMW 1 $33.41 $33.41
11-12-0-034-104 Gasket - Valve cover gasket set - right - ELRING 1 $12.48 $12.48
11-51-1-731-372/17 Gasket - Water Pump 1 $8.06 $8.06
4200276S Headlight adjusters 2 $65.28 $130.56 CA Automotive Aluminum Head-Light Adjuster
51-14-8-132-375 hood badge 1 $29.18 $29.18
11-53-7-505-229/21 Hose - Radiator hose 1 $50.69 $50.69
34-33-1-166-140 Hose - vacuum hose (BMW) 1 $24.58 $24.58 Brake booster hose
11-15-1-705-301 Hose - vent pipe - BMW 1 $37.44 $37.44 Ventilation Pipe from Oil Separator to Rear Cover, E39 540i/540i
11-53-1-711-385/21 Hose - Water hose 1 $25.34 $25.34 Water Hose - Radiator to Heat Exchanger
11-53-7-511-207/21 Hose - Water hose 1 $25.34 $25.34 Water Hose - Auto Trans Oil Cooler to Lower Timing Cover, (Alternator Housing)
11-15-1-726-339 hose clamp (BMW) 2 $1.73 $3.46
12-13-7-599-219-M618 Ignition Coil c/w spark plug connector - BREMI 2 $35.90 $71.81 1-748-017
63-17-7-894-018-M229 Light - M-Tech Fog lights (left) c/w lamp trim bracket (ZKW) 1 $75.26 $75.26
63-17-7-894-017-M229 Light - M-Tech Fog lights (right) c/w lamp trim bracket (ZKW) 1 $75.26 $75.26
07-11-9-906-361 O-ring 2 $1.54 $3.07
11-53-1-710-048 O-ring 2 $1.54 $3.07 O-Ring for Camshaft to Camshaft Timing Chain Tensioner (7.1 X 1.8 mm)
11-53-1-710-055 O-ring 2 $1.15 $2.30 O-Ring (34.2 x 4.0 mm), Water Pipe/Water Pump (2 per car, sold per each)
12-14-1-748-398/213 O-ring 1 $1.54 $1.54 O-Ring for Camshaft Position Sensor (17 X 3 mm)
11-51-1-705-408/213 O-ring - Thermostat 1 $2.30 $2.30
11-61-1-745-195 O-ring (BMW) 1 $4.42 $4.42 12-13-9-067-830, O-Ring - Intake Manifold Vent Pipe (12.5 X 2.0 mm)
66-20-6-989-068 Park Distance sensor 1 $41.86 $41.86
11-31-1-435-028 Plastic clips - plastic (BMW) 4 $5.76 $23.04 Chain Guide "Sliding Part" for Upper Camshaft Chain Tensioner (4 per car, sold per each)
11-61-1-440-135 Pump - Sucking Jet Pump (BMW) 1 $49.15 $49.15 Brake Booster Vacuum Valve - Intake Manifold to Brake Booster Hose (Sucking Jet Pump)
11-51-0-393-336 Pump - Water pump - GRAF 1 $79.68 $79.68 Water Pump, 540i/Touring (09/98-03), Each (Graf brand has metal impeller)
11-12-1-437-395 Rubber - Valve cover bushing 17 $1.01 $17.23 Valve Cover Nut Seal/Grommet
11-12-1-721-879 Rubber seal 9 $3.30 $29.72 Valve Cover Bolt Seal
61-61-8-217-711 rubber wiper blade insert 2 $9.79 $19.58
11-28-7-636-377-M21 Serpentine Belt - Continental CONTITECH 1 $16.70 $16.70 Belt - Alternator, Water Pump, Power Steering 7K X 1635
33-55-1-095-532/69 Sway Bar End Link - LEMFORDER 2 $17.47 $34.94
11-53-1-436-386 Thermostat -map controlled - BEHR 1 $64.32 $64.32
Grand Total $1,742.77
Package Price $1,200.00
BMW-Bryon is online now   Reply With Quote
Old 01-25-2018, 11:44 AM   #2
BMW-Bryon
Engine parts for 4.4 V-8 for Valley pan gasket replacement plus timing chain guides. I believe everything you need is here but I didn't do a final check that would be recommended before tearing the engine apart.
If you are doing one job or the other let me know. Make me an offer or I can put a package price together for you.
Tags
540i, 740i, e39, valley pan
