Go Back   maXbimmer Forums > maXimum Tech > 6/8 series
Thread Tools Rating: Thread Rating: 4 votes, 2.25 average. Display Modes
Old 11-22-2014, 09:16 PM   #1
gcunha
Seat warmer overheating
My sear warmer is overheating. My wife slightly burned her coat. Any thoughts to what the problem might be? Although my 645 is from 2005 I thing I might have a case with BMW Canada. Should the dealer should be responsible for it?
Thanks for all the replies in advance!
gcunha is offline   Reply With Quote
Old 12-02-2014, 06:02 PM   #2
i'd contact bmw canada directly, i'd maybe exaggerate the "discomfort" my wife had from this, i think you got a good shot at them fixing this. you could try to get them to replace the coat too but that's probably harder.
Old 01-23-2017, 11:16 AM   #3
Frankie1960
Good luck -I just went thru the whole process with BMW Canada, for my 2004 645 with 182000 km on it and they suggested getting a dealer diagnosis ($184), then stiffed me on covering anything. Mine had a hot spot on the left side bolster (reg seats not Sport) and wasn't burning thru so maybe you got coverage being a newer vehicle and fact of burning thru which seemed to help others in US, though on newer cars than ours.
Frankie1960 is offline   Reply With Quote
Old 02-23-2017, 02:35 AM   #4
nX07
nX07's Avatar
I had my 2005 645ci seat catch fire, drivers side. I went to an event and went to grab the car to pick up my girlfriend, I stepped outside after I put the car in park near the entrance. A few minutes later she came out and when I opened the door a plume of smoke came out. There were flames shooting out of my seat. I grabbed a bottle of water and doused it out. It burned about a softball size hole right into the seat.
BMW Canada repaired it free of charge, they were pretty good about it. The car was also originally a U.S. car too, I was a bit concerned about that but they still had no issues. The way I went about it was originally visiting the BMW Canada HQ, getting some random number the receptionist gave me. They asked me a bunch of questions over the phone and then made an arrangement at BMW Toronto to get it fixed.
I know the post is a bit old, but just putting this out here if someone experiences the same issue! There was a re-call done on the 5 series for this, and the heating unit I believe is the same.
nX07 is offline   Reply With Quote
Old 02-23-2017, 08:49 AM   #5
Blackedout95
Crazy, I have heard or should say seen where the pads circuit will cause over heating but never heard of a fire, scary.
E46
Old 08-31-2018, 01:31 PM   #6
UltimateFan
Found a new BMW Recall Tool
I recently discovered the BMW Canada website which allows you to search for active recalls on your BMW. Maybe your issue is covered by an outstanding recall?
Here is the link to check for yourself: www.bmw.ca/recall
UltimateFan is offline   Reply With Quote
Old 09-08-2019, 07:28 AM   #7
AvesHeter
Send a message via AIM to AvesHeter Send a message via Yahoo to AvesHeter
Could just be the little light inside the switch; this is what happened to mine.
The light inside the drivers-side switch no longer turns on, but the seat heater itself still works perfectly. I was told by my dealer that you cannot replace the light by itself; you have to replace the whole switch, and a switch was 50 plus tax, so I elected for now to just live without the light since the heat itself is still working.
AvesHeter is offline   Reply With Quote
