Old 08-16-2018, 02:28 PM   #76
Awesome, starting to take shape!
Old 08-26-2018, 10:03 PM   #77
Update from this weekend, spent some time Saturday buttoning up the rear sub-frame. I never took any pics but the gas tanks are back up. After bolting on my garagtastic poly subframe mounts and lifting the sub-frame back up into place I noticed that the diff hanger was too long. That's because the flange on the garagtastic mounts is welded in the middle of the bushing whereas the factory flange is offset, this caused the sub-frame to be raised about 3/4". So I sliced the hanger in half... trimmed some out and tacked it to test fit...
Fitment was good, so I welded it up, painted and installed...
After that the axles went back on along with the BC coils...
Man those rear axle nuts are crazy... 295-347ft-lb torque spec! My torque wrench only goes to 150ft/lbs... just went by feel after that with a bigger breaker bar until the castle nut lined up with a pin hole.
Gasser style haha
Old 08-31-2018, 06:10 PM   #78
Old 09-13-2018, 02:50 PM   #79
Update on the coilovers...
The gland nuts on the shock assembly were rusted good and tight... fortunately I didn't need that part anymore... it just meant that I couldn't pull the shock out before cutting the housing....
That meant that I had to very carefully cut through the housing without cutting into the shock body... #TrustMeImAnEngineer...
Success
After that it was just a matter of wire wheeling and welding...
And back on the car....
Old 10-19-2018, 09:49 AM   #80
It's been a while... because I bought a house and am knee deep in renovations... progress will be slow for the next few months...
Recently on thanksgiving weekend, I gave thanks for the EFI M10 motor that I picked up for free a while back, because the one that I had bought before that one must have sat unused with no oil in it for a long time and had too much rust in the bores to use as-is.
So I swapped engines on the stand and started basic tear down to inspect condition and clean things up...
It looks like someone must have had this motor out for a refresh at some point because the block has good coat of black paint on it and some newer yellow zinc bolts on some brackets. I tried picking at the paint and it's on there good, not just a quick and dirty job over the old flaky rust that tends to accumulate on these old blocks.
The valvetrain was also really clean, leading me to believe that the head had been off recently... hopefully not for any terrible reasons...
The only thing I found so far was that the head has a hairline crack on one of the spark plug holes that had been sealed up.
Since it's not structural and there is no evidence on the outside of the head or block that it had been leaking recently, I'm just going to leave it for now. My goal right now is to get the engine in the car and start working on the wiring harness for megasquirt. I have a spare head on the motor I'm not using that I'll clean up and have ready to go in the event that this one starts leaking.
That's all for now.
Old 11-20-2018, 12:20 PM   #81
Minor update:
Had a few hours to spare this weekend so I continued working on cleaning up the motor.
I'm pretty well done that task now. Next I'll have to give a few things a coat of paint, then I can re-seal it and drop it into the car so I can start working on the wiring harness.
Old 01-06-2019, 06:55 PM   #82
Hello again... quick update...
Over the Christmas holidays I had some time to crack open the MS3 that I bought 2nd hand. I installed the MS3X board and using a couple of gator clips with a 12V DC power supply and a piece of scrap wire I was able to power up the unit and load firmware to it. It should be good to go now when I need it...
Today I took the hood off and got the engine dropped in temporarily...
Now to find some time to start working on laying out the wiring harness!
Stay tuned.
Old 02-12-2019, 11:31 AM   #83
Quick update of what's happened in the last month or so...
Took the engine harness off the original motor and labelled everything...
After carefully cutting off the casing, I used the ETM and traced all the wires from the relays to the engine connectors and cut out everything that I wouldn't be needing to run megasquirt. The pile on the right is what I'm keeping...
After that I pulled all the wiring out of the sheathing on the universal harnesses for the MS3 and MS3X, separated all of the wires I need and the ones I don't. Then combined the ones I need and stuff them back into a single sheathing. The pile on the left is all the wiring I don't need...
Pulled it though the firewall and then peeled it back out of the sheathing...
And then set about roughly running the wires to where they need to be and trying to keep everything tidy....
After that I prepped the injector pig tails that I cut off the E30 M10 harness, the old sheathing was hard and cracked so I pulled it off along with the rubber boots, put some new heat shrink and reinstalled the boots
That's about it for now, I'm planning on making the injector harness modular along with some other wiring possibly so I ordered an automotive connector kit that should be arriving this week.
Old 02-25-2019, 11:23 AM   #84
tominizer
Following. Nice work.
Tom
Old 04-08-2019, 03:48 PM   #85
Sorry for the lack of updates. There hasn't been a ton of progress in the last couple months as I've been going crazy trying to get my house renovation done(ish) before the wedding. But since I also want to use the car in my wedding I guess I'll have to start going crazy on it sometime soon haha.
Anyway, I got the wiring harness into what should be a functional state. I don't want to wrap it all up until I know it's good. No real pictures of that whole process, but it was tedious, and tricky to say the least. So I pulled the motor back out for final assembly...
I wanted to mount the VW coil pack that I'm going to be using in the same spot as the distributor so that plug wires would be similar. In order to do this, I had these pieces made up... the young guy working on them messed up the hole pattern a couple times as you can see... third time's a charm lol...
After that I tacked on my trigger wheel to check fitment on the motor.
No pic on the motor right now, but it fit nicely. Now I need to make up a bracket to mount the crank sensor.
After that I cleaned up the firewall and installed some automotive peel and stick heat shield... hopefully it holds up ok...
Right now I'm just working on cleaning up the brake booster and reinstalling brake lines and everything else that should go back in before the motor.... like the wiper linkage. I needed to order new damper rings for the wipers.... $30 each for a couple rubber rings
I also need a new hard line for the clutch slave because I went and cracked and cleaned up all the hydraulic fittings while they were out, but the fitting that went into the slave was too corroded and twisted the line.
Motor should be going back in either this weekend or next weekend. Then it will be testing the wiring harness
If all goes well I should be trying to crank it over before the end of the month.
Old 06-12-2019, 11:19 AM   #86
Sorry for the dead build thread. Between my house renovation, the car and my wedding I haven't had much time for anything else in the past couple months. Unfortunately the car did not make it to the wedding like I had planned but it is at least running now, so the end is near.
Here's a rough update based on the few pics I do have on my phone...
Before I put the motor back in I had to make a bracket for the E30 crank sensor. Time for some cardboard aided design #CAD
Then I could put the motor back in and hook everything back up...
I also ran a power cable and fusible link from an E46 so I could put the battery in the trunk.
Old 06-12-2019, 11:45 AM   #87
Once I had the motor in I was double checking the timing and as I went to turn it over by hand it would get to a point and then bind like it was hitting a dead stop. I was shitting my pants thinking that something had fallen into an intake or exhaust port and was blocking a valve or something but also thought maybe I made a mistake installing the flywheel/clutch as well. So the first thing I did was crack apart the transmission as far as I could while still keeping the longer bolts engaged. Fortunately I saw this...
The timing tooth that got added to the E30 M10 flywheel for the flywheel sensors was just barely hitting the bell housing of the E21 transmission, I could see with a light where it was contacting. So I just chamfered the edge of the tooth a couple mm and bolted the trans back up and it rotated freely.
This is a case where RealOEM shows the part numbers are the same, but BMW obviously didn't check that it was backwards compatible.
After that I went to mount up some 90's integra seats that I got from the wreckers for cheap. The material is roughly the same but the seats are much nicer than the stock E21 ones are. The procedure ended up being fairly simple. Remove the integra seat rails and the E21 seat rails. On the inside rail the E21 rail will bolt up with a simple bracket.
Here you can see the rear mounting hole being used...
Then a piece of flat bar to bridge...
The outside rail is a bit more work. Need to drill out the spot welds on the integra rail to remove the brackets that bolt to the side of the seat...
After that bolt the side brackets back up to the seat with the E21 rail (using the back bolt hole) and mark where the side brackets land on the E21 rail. Then remove, clamp together on the marks and weld. I don't have an after picture, but this is before welding...
And then after install...
After this point I ran into some issues with the megasquirt. I don't really want to go through it all...but the short of it is, either there was something wrong with the ms3x card, or I did something to it that damaged it, and after a week and a half of trying to troubleshoot it, I ended up ditching the ms3x and the coil pack and installing a high current driver to the main board and going back to the stock distributor and coil set-up and was able to get the car fired up.
Now I just need to bleed brakes and clutch lines, slap the hood and fenders on and I should be able to start street tuning it.
Here is how she currently sits...
