Old 10-17-2016, 05:50 PM   #241
Sea Aych
Sea Aych's Avatar
Anybody got any recommendations on where to get a good quality + costco-priced battery for the e30 around the GTA?
Every costco i've called said they no longer stock batteries for BMW...
Sea Aych is offline   Reply With Quote
Old 10-17-2016, 09:29 PM   #242
SubDad
Part Source or Canadian Tire. Or NAPA or even Sears. Or go back to Costco with a tape measure.
No, really! Batteries are a commodity like tires or gas or wiper blades.They come in sizes and aren't car model specific.
Measure the space you have available, note the terminal positions and get the biggest battery that fits with the most cranking amps and reserve life. Don't go too cheap, or spend too much on some fancy woowoo battery. All batteries are on borrowed time after 5 years.
Your battery's probably in the trunk so you'll want one that vents overboard.
SubDad is offline   Reply With Quote
Old 10-17-2016, 09:50 PM   #243
Sea Aych
Sea Aych's Avatar
Thanks! After a roadside incident this evening, it's definitely not the battery (which I temporarily replaced - gotta return it tomorrow).
Car started fine, drove to the grocery store, then car wouldn't start back up.
Get all the lights on the dash, the main relay clicks, but when I turn the key to start, nothing.
The first couple times I tried to restart the car, I got a single click from the starter, but then after that nothing.
If i hold the key in "start" for 15-20 seconds, I occasionally get a whmmp as if the starter wants to turn but wont.
I tried the 'ol tickle the starter with a hammer trick while trying to crank it over, but nothing.
Any ideas folks?
Old 10-17-2016, 10:19 PM   #244
SubDad
I hate to be *that guy*, but they're are a lot of "No crank" diagnosis threads.
Anything written by "jlevie" is E30 truth, but your swap changes some subtleties.
Battery connections? Ground?
If the lights go dim when you turn the key power is going somewhere, and it's probably the starter. I'd start (sorry) by charging either of the batteries and seeing what happens. (Voltage at rest, voltage while cranking, smoke rising from the starter, etc.)
If the high beams and the vent fan are bright and loud before trying to start, your battery is probably good enough, but honestly, a lot of times people will chase their tails for a bad battery. I know you borrowed one, but you don't really know what shape it's in.
Old 10-17-2016, 10:24 PM   #245
Sea Aych
Sea Aych's Avatar
No, no, all help appreciated! He's usually my go-to as well.
I actually popped into walmart nearby and grabbed a brand new one! Checked in the store with a multimeter to make sure it was charged up too.
Jump starting made no difference either.
Cleaned up the connections, but didn't get a chance in the dark and without my tools to check the ground in the engine bay.
When i get the key to "start", lights go dim/off, radio and all that jazz shut off, but I get nothing. Hence my first guess at the starter - i'll have to look into it during daylight in the next couple days after work I guess.
Old 10-17-2016, 10:38 PM   #246
SubDad
Good luck to you, I'm sure daylight and tools will solve it. Let us know what solves it so we can save it to our collective memory.
Old 10-18-2016, 05:11 PM   #247
estoguy
When I got my E30 from my best friend, he had a spare battery from a VW diesel, big sucker. It's been in my car for 4 years, and it's never left me stranded. I tested it last spring with a load tester, and it was still testing strong. And the battery is about 6 years old...
Volkswagen battery 000 915 105 DH, 80Ah 380A DIN 640A SAE. Equivalent to BCI Group 94R and they aren't that expensive, one website, German Supply had it for $138 in a quick search.
1986 325 ~Elsa~
Alpenweiss
Need a photographer, come visit my site: http://estoguy.wix.com/unique-perspectives
"The future is uncertain and the end is always near."
estoguy is offline   Reply With Quote
Old 10-18-2016, 09:02 PM   #248
SubDad
^^ Yep, I had a 1976 Audi Fox, like a Dasher. Like a Rabbit. Golf. Oh never mind, you youngsters. A VW 4 cylinder gas, manual, sedan.
Anyway, I went to Canadian Tire to buy a battery, mentioned to the guy that I had a hard-start when hot condition* and he, they're not all stupid, said "Why not buy the battery for the diesel automatic version?" So I did. Could probably have driven 20 km just on the starter, and it lasted 3 more cars.
*Bendix mechanical injection, 5th injector controlled by a bimetallic strip. They were not available in junkyards and I couldn't afford new.
Old 10-19-2016, 02:52 PM   #249
That old ground strap from the oil pan to the chassis will getcha every time...
Old 10-19-2016, 06:51 PM   #250
Sea Aych
Sea Aych's Avatar
Back from using a multimeter and poking around.
Pulled the ground strap out and it looked/tested good! Nice and shiny too
Battery is all good (even the old one), outputting ~12.7 volts with the car off.
Getting a solid 12v to the starter, power's where it should be, and the two smaller wires coming of the starter (unloader circuit and the solenoid power) look good
Then finally, when trying to start the car, I hear a "chk-chk" from the starter. and that's it. Sometimes it won't even do that.
Bleh.
I should mention too that the starter's been acting up for over 6 months, not always disengaging after the car starts, squealing to all hell for a couple seconds
Old 10-21-2016, 11:03 AM   #251
Pull the starter and bench test it.
Also, just because the ground strap looks good doesn't mean that there isn't some oxidation or crud on the posts where it mounts. Make sure all the mounting points are nice and shiny
Old 10-21-2016, 11:08 AM   #252
Yamahammer
Warlock of the century
Yamahammer's Avatar
Are the positive's on the start solenoid loose or corroded or something? Do you a get a low resistance when measuring from the alternator to the positive block on pass side?
The starting hanging up is usually from the ring gear/pinion alignment, not really electrical related.
If you want a different starter to try I have 4 sitting sitting around.
Old 10-21-2016, 11:08 AM   #253
Yamahammer
Yamahammer's Avatar
Woah, hey
Old 10-22-2016, 07:29 PM   #254
Ceeker
These are pretty simple systems. You have a short. As mentioned; I'd inspect the ground strap even with the plastic covering it moisture can get in and corrode causing problems and as Bullet ride said is a very common problem.
Try this for out for shits and giggles: Ground the engine from the valve cover to the firewall or shock mount tower and see if that changes anything. If it does then you know it's a ground issue. If not, then most likely internal starter or solenoid.
rebuilt starter from any rebuilder is about 100.00
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 10-25-2016, 02:48 PM   #255
Sea Aych
Sea Aych's Avatar
I'll send you a PM! Even if this doesn't end up being the problem I'd like one that doesn't squeal constantly!
Picking up the ground strap today after work - will try that too!
Thanks again for all the help
