Old 11-16-2016, 11:43 AM   #1
wolf_e39
wolf_e39's Avatar
E38 750il Electrical issue
hey guys i recently got a 95 e38 V12 and i have a few issues that seem a bit unnusual.
1. if the battery is disconnected only the trunk can be unlocked with the key. the drivers door lock spins with the key but it does not lock/unlock the door.
if i use the remote itself car locks and unlocks normally without a problem.
2. when i turn on the lights inside the car the hazard button will start flashing immediately (not the lights outside the car only the button itself) i can still turn on and off the hazards but the button flashes constant. also the cluster and all the stereo back lights will have a sligh flash as well.
has anyone ever encountered this problems
wolf_e39 is offline   Reply With Quote
Old 11-17-2016, 09:01 PM   #2
The first one is normal, security feature, if the car is locked and battery disconnected, you NEED power again for it to unlock!
Most models E30 E36 E46 E90 E92 E93 E28 E24 E34 E39 E60 E61 E32 E38 E65 E66 X3 X5 M3 M5 Z3 Z4 F30 F32 F10 F01
Old 11-17-2016, 10:21 PM   #3
Blackedout95
You do not have two issues you have one
See your hazard light issue, not sure if you know it but that why you disconnect the battery, its draining dead isn't it...because of the hazard light issue!
Fix the hazard light issue will result in you not disconnecting your battery which leads to your key working
I am just too tired at the moment but google has plenty of info on the hazard light issue, many different types of symptoms flash no flash, solidly on, goes off over bumps etc. Find yours and the cause. Sometimes as easy as a new switch sometimes not.
Good luck
E46
Old 11-18-2016, 09:21 AM   #4
wolf_e39
wolf_e39's Avatar
Even if i leave the car unlocked and then disconect the battery and try to lock it with the key the car will not lock. Isnt this a security thing you should be able to open a door if your battery is flat ?
Blackedout95
Its not only the hazard button all the lights inside the car fluctuate while the car is idiling.
Now i did check last night and found out my alternator has kicked the bucket so i will change that first and go from there
Old 11-18-2016, 10:55 AM   #5
Blackedout95
Blackedout95
That certainly makes perfect sense and as to why battery dies
Start there.
E46
Old 11-18-2016, 12:16 PM   #6
The feels when you're right!!
['07 BMW M5/6.:Indianapolis Red/Black:.
'93 BMW 850i J Spec
94 BMW 850 CSi
91 BMW 850Ci Manual
'81 MB 500 SEC Koenig (pearl white)
00 BMW 750iL J Spec- Alpina Mods
06 MB S65 AMG
09 911 4S
11 BMW M3 DCT Competition
12 BMW 328i M Sport Convertible
Old 11-21-2016, 07:17 PM   #7
Yup, the E38's hate low voltage, and will throw random gremlins when they don't get the juice.
Test the battery while you're at it.
Old 12-26-2016, 10:46 PM   #8
wolf_e39
wolf_e39's Avatar
THE PROBLEM SEEMS TO HAVE GONE AWAY.
After changing the alternator and fixing some wires under the driver seat all is back to normal.
File Type: jpg 15556286_10154780555529631_1853982941_o.jpg (191.6 KB, 24 views)
