Old 12-05-2007, 04:25 PM   #1
Mickey Knox
clutch fan removal tool
good afternoon fellas!
I am in the porcess of putting together all the bits and pieces to do a cooling system overhaul on my 1993 325is, which will include a fan delete and waterpump replacement.
all sources i have researched so far suggest that this clutch fan removal tool is essential to get it done
http://www.zdmak.com/wbstore/main.as...h=&LowCt=0&PG=
anybody that can confirm that this is 70 dollars well spend, or are there creative ways to get it done without breaking my fingers in the process?
TIA
mickey
Mickey Knox is offline   Reply With Quote
Old 12-05-2007, 04:35 PM   #2
archrival
E36 Addict
archrival's Avatar
nope!!!!not worth it...go to any place and buy a 32mm wrench and hit the end of it with a hammer to give it a few jolts to crack the nut loose. cost will be under 15$ this way.....make sure the belt is still on or you will not be able to get it cracked loose
archrival is offline   Reply With Quote
Old 12-05-2007, 04:42 PM   #3
Mickey Knox
aha
I figured there is a way, will do.
TY sir
mickey
Old 12-05-2007, 05:40 PM   #4
ScotcH
Princess auto has a similar tool for a few $$, incase just wacking it does not work.
Old 12-05-2007, 05:52 PM   #5
mirek
mirek's Avatar
Just get a bike tool, you can get it pretty much at any bike shop, it's a thin wrench with 32mm on one end and 34 on the other. Works great.
Old 12-06-2007, 01:11 PM   #6
UltimateDriv
Bimmerhead
UltimateDriv's Avatar
Send a message via AIM to UltimateDriv Send a message via Yahoo to UltimateDriv
i have it and i absolutely think its necessary...my fan was on so tight that it was difficult even with the tool.
$70 is overpriced however...i paid $30 for the fan removal tool, i believe on ebay.
and $7 for a bicycle 32mm wrench also on ebay
http://cgi.ebay.ca/Wrench-Force-32mm...QQcmdZViewItem
http://cgi.ebay.ca/BMW-Fan-Clutch-Nu...QQcmdZViewItem
UltimateDriv is offline   Reply With Quote
Old 12-06-2007, 06:52 PM   #7
Karim@Corner73
Karim@Corner73's Avatar
I confirm it is harder, but very doable without the tools.
Karim.
Old 12-06-2007, 09:28 PM   #8
BmW1819
ebay for 30$ shipped with a 32
Old 12-06-2007, 09:51 PM   #9
Mr.535
Mr.535's Avatar
If you had access to an air hammer you could make a knotch in the nut then use an air hammer to crack it. Worked once then I shaved the end of a wrench so it would fit into the air hammer and it worked amazingly without buying the kit.
2001 Laguna M3
1989 535i -11:1 N/A M30 complete,BW S375 build begins
Mr.535 is offline   Reply With Quote
Old 12-07-2007, 01:08 PM   #10
Mickey Knox
thx guys
thank you fellas,
just ordered it from ebay, dont know what got into the guys at pelican they usually have pretty decent pricing but this one was over the top
have a ticket free weekend
mickey
Old 12-07-2007, 02:24 PM   #11
98Dinan3
98Dinan3's Avatar
I made my own out of a piece of flat aluminum bar stock. A drill, a grinder, and ten minutes... I've got a tool. Cost...Free
Old 12-10-2007, 08:20 PM   #12
Dr. Flyview
"Mint"
Dr. Flyview's Avatar
I tried to do it with a 32mm wrench alone...impossible. We tried for an hour or more. You need something (fan clutch removal tool) to hold down the waterpump from spinning while you break the fan clutch loose with the 32mm wrench. You can borrow the fan clutch removal tool from canadian tire (you pay for it though then get your money back when you return the kit) however, the kit does not have the 32mm wrench but the fan clutch tool in there will work, you just also need to find a 32mm wrench.
1998 BMW 328is - summer
1993 BMW 525i - sold
1994 BMW 325i - sold
1992 BMW 325i - gone
sold
Old 12-11-2007, 01:27 AM   #13
archrival
E36 Addict
archrival's Avatar
I just leave the belt on and smack the wrench with a hammer...never fails...air hammer is also an easy option...hit it on the edge of the nut and crack it loose
Old 12-11-2007, 09:35 AM   #14
INFAMOU$
Automotive Puppeteer
INFAMOU$'s Avatar
+1.. never needed a fan removal tool..
INFAMOU$ is online now   Reply With Quote
Old 12-11-2007, 07:04 PM   #15
archrival
E36 Addict
archrival's Avatar
our driveway must just be the e36 service center
things just work haha
