Old 09-20-2019, 07:34 PM   #1
jsonli
DSC and Brake Light on after alignment
I recently had an alignment done at the Altech in Etobicoke cause the car seemed to be handily pretty sloppy.
Guy said my alignment was pretty out of whack, and that my tie rods were seized. He'd torch it to heat them up and loosen it to get the alignment as close to spec as possible.
He did it, and the car drives a lot better now (although steering wheel is still not straight, off by 5-10 degrees), but the DSC and brake light came on the day after, and still has not gone off after 500km of driving.
Could the shop maybe have messed something up?
Or is just a matter of waiting longer for the computer to adapt to the newer alignment? Can I reset anything? I've tried pulling the battery.
jsonli is offline   Reply With Quote
Old 09-23-2019, 12:13 AM   #2
jabela
Is the handbrake fully released?
Otherwise it sounds like an ABS sensor is damaged. Make sure they're plugged in properly and look for damage, especially melting or something.
www.maisonapothecare.ca
Old 09-29-2019, 10:35 AM   #3
Espritv8
Espritv8's Avatar
I don't think an alignment would affect your ABS DSC unit in any way.
He most likely damaged one of the ABS sensors. That's the only thing I can think of.
Espritv8 is offline   Reply With Quote
Old 09-30-2019, 10:00 AM   #4
jsonli
It was fixed by straightening the steering wheel, and also a recalibration of the steering angle sensor.
Basically, the DSC system needs to know what angle your wheels are pointed at accurately in order to determine when your car is sliding and when it isn't.
My alignment was pretty bad before, so the inputs were so different compared to before that the system was confused and refused to work.
