Old 03-03-2011, 05:39 PM   #1
BennyL
7th Gear Member
BennyL's Avatar
Stupid question? Maybe...
So I'm thinking of getting an E46. Haven't decided which one, don't really have a preference for any specific engine.
I'm wondering if it's safe to run any of them on regular gas (87 octane). And if so, what are the effects.
I did a quick search and didn't come up with anything. So, any input ppl?
Old 03-03-2011, 07:49 PM   #2
Syn
You don't have to put 91 in but its preferred, now I'm no mechanic but I had the same question in other thread. 330i I purchased had check engine light come on when it had 87 put in - code read (E4 Fuel Trim Bank 2, permissible range exceeded)
Somebody please correct me if I'm wrong ;-)
Syn is offline   Reply With Quote
Old 03-06-2011, 09:19 PM   #3
blakneto
blakneto's Avatar
You can use 87... but its not recommended for performance reasons.
Think, garbage in/garbage out.
The e46 is tuned to use premium gas for premium performance.
There is a fuel filter that would have to work harder (or wont be able to) to clean the impurities in the gas. It could damage your engine over a extended period of time.
But I am not a mechanic...
Call BMW Autohaus or Budds or whoever and talk to the service techs there.
They are pretty good with giving answers to BMW owners.
Old 03-06-2011, 09:51 PM   #4
Will the car blow up? No. (it has knock sensors that will retard the timing).
Are you going to save any money by doing this? No. A car is tuned for a specific gas and is optimized to run on it. Its cheaper to drive 100km in a car that is tuned for 91 on 91 (considering the 12% higher price) than it is to drive that same 100km on 87 (even though the gas is cheaper).
Just put what it says on the cap.
Old 03-06-2011, 09:58 PM   #5
Renboy
First things first, the term 'premium' is a marketing ploy. It is not better gas than regular, it's different gas. If you want good gas, go to Petro or Shell since they don't use ethanol (yet afaik), and avoid esso, pioneer, sunoco, and essentially all others. There are no more impurities in 87 than there are in 91 so your fuel filter WILL NOT get damaged. Furthermore, the engine isn't tuned to the point where damage will occur if you run anything less than 91, even over an extended period of time. If it did get damaged under these circumstances then there wouldn't be any possibility of tuning the engine any further, or running boost on this engine. Think critically, if you needed to run 91 stock, then how could anyone push 6-8psi on the same gas without damage....answer is they couldn't. Furthermore, the octane rating is actually a ratio of septane and octane (two different types of gas). 87 has as you would imagine 87% octane and 13% septane. Does this really matter, well since septane has more btu's than octane, yes it does because you get WORSE mileage out of an engine if you run higher than needed octane...yes, you did read that correctly. Most people look at a compression ratio and automatically assume that alone defines what type of gas is required, that's an incorrect mentality. Compression ratios are important, but so is the material the block is made of, the material the head is made of, the altitude the car is driven in, the humidity the car is driven in, the air temperature, the rpm range (based on idividual drivers), the load (if the car is towing or full of fat people), the temp of the spark plug, the type of fuel delivery, the list can go on for quite some time I've just listed some for illustration purposes. The reason a company like BMW will put a 91 octane required sticker on the gas cap is to imply exclusiveness, and protect themselves. If they didn't put that sticker there you can be damn sure that some jacka$$ would drive the car through a desert, while towing a camper with the A/C on and farting along at 1200rpm...essentially destroying the engine while the car was under warranty.
From my personal experience, when I'm driving on winter tires, I use 87, when on summer tires, 89. And from what I've read compared to other e46 owners I get much better mileage than average. This is owning 2 non-m e46's ('01 325Ci, and '04 330Ci).
Old 03-07-2011, 02:01 PM   #6
blakneto
blakneto's Avatar
WOW! now that is in-depth!
Thanks Renboy for the correction!
Remember... I'm not a mechanic! :p
Old 03-07-2011, 02:54 PM   #7
Renboy
I'm not a mechanic either, just what I've learned.
Old 03-08-2011, 01:19 PM   #8
andrew.k
Top Gear Professional
andrew.k's Avatar
Simple, car was tuned by BMW to run on 91, pay the few extra dollars, and get a few extra km's. It all equals out.
E92 M3 Carbon
andrew.k is offline   Reply With Quote
Old 03-08-2011, 02:20 PM   #9
Renboy
^^^ How insightful, you've managed to make a point with burdening yourself with proof, logic, or even theory.
Old 03-10-2011, 11:45 PM   #10
BennyL
7th Gear Member
BennyL's Avatar
Right, so what I'm seeing is some people who know nothing about gas saying to use 91 cuz that's what the car tells you to use and a guy who seems to know lots about gas and actually has experience using 87 saying it's no problem.
I think I'll take Renboy's word for it. Gonna get an E46 and run it on a few tanks of each and compare my gas mileage. As far as damaging the engine is concerned, I'm convinced that will not (and can not) happen.
Thanks.
Old 03-11-2011, 02:44 AM   #11
The-Traveler
I didn't read your entire post but I wanted to correct your ethanol statements. Shell is the only station (AFAIK) that does not use ethanol, and that only applies to V-Power (91). The other grades do have ethanol, says so on the pump.
Petro has ethanol in all grades.
Essa has ethanol in all grades.
The-Traveler is offline   Reply With Quote
Old 03-11-2011, 04:49 AM   #12
DIRT_Racer
DIRT_Racer's Avatar
Esso in my town has no label for Ethanol, I have asked the Manager they have been told BY THE Supplier their gas there is NOT an ethanol blend. other stations farther from the refinery may be, but theirs is not. Does it make a differance that the station is only 40 KM's from the Esso Nanticoke Refinery, I do not know. But they are not Ethanol blended and thats what we use in our stock cars.
DIRT_Racer is offline   Reply With Quote
Old 03-11-2011, 11:07 AM   #13
Renboy
I've done some quick (very quick infact) searching and found that ethanol content is not only dependant based on province, but apparently the location within that province. Here's a copy of an email from Petro (found on another site)
Thank you for contacting Petro-Canada Customer Service online.
Sorry for the delay in our reply.
At Petro-Canada branded gas stations, not selling Ultra 94, the Premium 91 Octane gasoline does not contain ethanol. This is for stations up to the Muskoka area and from Windsor to Belleville..
In Northern Ontario, North Bay, Sudbury, S.S. Marie, Timmins, Thunder Bay areas and in Eastern Ontario for the Ottawa areas, including Pembroke, Cornwall and Brockville, both Regular and Premium gasoline currently do not contain any Ethanol.
Should you require further assistance please do not hesitate to contact us.
Regards,
Suncor Energy Inc.
Customer Relations
I'm going to email Petro, Sunoco, Esso, and Shell to see exatcly what each one says and post back.
Old 03-11-2011, 05:50 PM   #14
Thank you for a well versed, fact based response.
My question is, based off your statements, I can run my M5 and my High pressure Turbo Volvo on 87 Octane without any repercussions even though they both call for 91+ octane.
Old 03-12-2011, 07:11 PM   #15
sparkybp
Tortures BMWs.
sparkybp's Avatar
I can see what your saying but I didn't take the post he made in the same manner that you did, out of everything, I took home the fact that you should use the recommended octane rating gasoline for your vehicle basically. In between all that he wrote, the fact is your turbo Volvo requires a higher octane gasoline that a NA vehicle. As for NA vehicles, if a mid grade octane is suggested, it should be used, and a higher octane gas in such a vehicle could POTENTIALLY damage your vehicle or not make a difference in mileage if the DME doesn't know that it exists which is only in very rare cases. Most cars can determine, using several sensors,what they are running on and make necessary adjustments to the fuel trim and or timing for optimum fuel economy and lowest possible emissions.
Good discounts on all OEM and good quality aftermarket BMW parts. 519-498-9660.
