Old 05-18-2004, 02:02 AM   #1
Autotechnica
Little Chino
possible clutch problems, help please
I've been having some really odd sounds from the clutch today. I drove around and I noticed when I press down on the clutch all the way it makes a really loud rattling and kinda grinding noise (doesn't sound good). Then with the clutch fully depressed, I rev it a few times and hear a loud whirling noise. When I release the clutch and give it some gas in gear the clutch makes the car choke a bit and sometimes it slips a lot. The odd thing is the previous day the clutch gripped like it was brand new, it showed no signs of slipping at all. When I drive around I still hear the rattling and whirling but it's not as loud.
I'm guessing it could a number of things. I haven't worked on the clutch before so I'm a little clueless when it comes to this. Could it be the teeth on the pressure plate have broken off or damaged? Could the release bearing be worn?
I've got a brand new M3 clutch kit in my basement so I'm not worried. However, before I just install it I want to know what's wrong.
Any help greatly apprecaited.
Thanks,
Bryan
Old 05-18-2004, 05:19 AM   #2
teddy317
teddy317's Avatar
need to change the clutch get a kit for that with release bearing thats certain also check the flywheel ..and that solve yr problem but that noise is worn clutch ...
teddy317 is offline   Reply With Quote
Old 05-18-2004, 05:26 AM   #3
Autotechnica
Little Chino
Thanks Teddy,
Do you think it's safe to drive around for a while? Or should I get it replaced immediately?
Bry
Old 05-18-2004, 05:27 AM   #4
teddy317
teddy317's Avatar
it safe to drive for a while but i dont think you can stand that noise .
Old 05-18-2004, 05:29 AM   #5
Autotechnica
Little Chino
Yeah it's really loud, sounds like an old winter beater.
Anyways, it won't damage the tranny or engine?
Bry
Old 05-18-2004, 05:29 AM   #6
teddy317
teddy317's Avatar
nope . just clutch..
Old 05-18-2004, 05:33 AM   #7
Autotechnica
Little Chino
thanks
This is a long shot, but any idea what other parts I need if I'm swapping an M3 clutch into a 318?
Bry
Old 05-18-2004, 01:52 PM   #8
teddy317
teddy317's Avatar
i have no idea for swaping, i don't know if they are the same size anyway to finf out call bmw autohouse they will tell you if theres no difference...in swapping..advice better to use stock and get a light flywheel that will help yr performance//..
Old 05-18-2004, 02:28 PM   #9
djcontra
Gets Blown Daily
djcontra's Avatar
put an e34m5 clutch and uuc flywheel in!
Mods
-Shortstack headers
-Vortech RRFPR
-255LPH Walbro fuel pump
-Keskin KT1 17x8.5 & 17x10
-Remus full catback
-SMT6 EMS (Untuned)
Old 05-18-2004, 04:57 PM   #10
Autotechnica
Little Chino
I already bought an M3 clutch a while back, don't want to spend more money.
Anyways, what do I need for the conversion?
M3 slave cyl, pilot bearing, release bearing?
Anything else?
Also, will a clutch disc from a '97 M3 fit a '95 M3?
Thanks,
Bry
Old 05-19-2004, 12:44 AM   #11
thinair
moderationistismingly
thinair's Avatar
Hold on, are you using a stock M3 flywheel? If so, what is the advantage of running the M3 flywheel, and an M3 clutch kit over a stock 318 clutch kit?
I know the M3 flywheel is slightly lighter, but if you're going through the trouble of changing it, you should go to an aluminum flywheel, or at least a machined single mass flywheel.
Old 05-19-2004, 02:46 AM   #12
Autotechnica
Little Chino
It has better clamping force. It can handle up to 450+HP incase I ever decide to add more power. Most importantly, my stock flywheel is probably damaged as I have actually been driving on a worn clutch disc for quite some time now so this replacement is mandatory.
An aluminum flywheel costs more money which is money I can't afford to spend right now. The labour would prove to be the most expensive part of this replacement so I've decided to go with the M3 clutch kit that I already have in my posession. Anyways, the main thing I want is a grippier clutch and I feel those "sport" clutch kits are a total waste of money.
Question, do I need an M3 clutch release fork?
Thanks,
Bry
Old 05-19-2004, 03:52 AM   #13
Autotechnica
Little Chino
I had a little too much time on my hands so I painted them
Old 05-19-2004, 03:54 AM   #14
Autotechnica
Little Chino
