Old 05-16-2004, 08:47 PM   #1
noochie1
my overheating problem
ok so yesterday I flushed the cooling system but the prob is still there. The auxillary fan kicks in and main fan is good. One think I noticed is that If I turn on the heat to full blast while idleing the temp will go back towards normal temp. Does this mean that I need a new water pump. My cars build is 7/95 I thought that the metal pumps started after 1/95?
noochie1 is offline   Reply With Quote
Old 05-17-2004, 12:47 AM   #2
BMWF1
Guest
Posts: n/a
Make sure you use BMW Coolent or it will overheat
Old 05-17-2004, 03:00 AM   #3
koncise
all you need is one mike
koncise's Avatar
Send a message via MSN to koncise
really? My temp gauge must be broken then.. cuz I've never used BMW coolant since buying my car and the needle is always in the middle
koncise is offline   Reply With Quote
Old 05-17-2004, 05:44 AM   #4
BMWF1
Guest
Posts: n/a
well i dunno, i put some Canadian tire fluid in, just to top it off and BOOM overheat
Old 05-18-2004, 08:56 PM   #5
noochie1
GRRRRR!!!!!!!!! now my frickin radiator bleeder valve plug broke and spewwed everywhere.
