Thread Tools Rating: Thread Rating: 59 votes, 5.00 average. Display Modes
Old 03-25-2010, 06:39 PM   #826
murcielago54
murcielago54's Avatar
Send a message via MSN to murcielago54
Originally Posted by 325isStephen View Post
Bigger lips, DO IT NAOW
3 inch all around would work nicely. stretch some 195'50's, if you feel like going lower then I was try 45's
yeah i wanted to do that, i bought a set for cheap, i had them refurbished and then i found out that the 3 inch lps are... well pricey
so i'll stick with stock lips this year i guess
but i agree, 3 inch lips on RM on an E30 is gorgeous
Originally Posted by Ian View Post
My bet is on 2 pieces of stale bread soaked in urine and animal seamen, painted "Motec gold" and taped to the dashboard along with a lock of his godfather's hair (for protection from the evil car spirit gods)
murcielago54 is offline   Reply With Quote
Old 03-25-2010, 10:00 PM   #827
Originally Posted by SamE30e View Post
For 100$ with tires, I could get spacers.
16" Hocks.
To bring it close to the fender I could go 20mm right? That'll be +15.
Yeah, stagger them though. 15F/20R spacers.
Old 03-27-2010, 06:02 AM   #828
MotorsportsR
Would 17x9 +25 offset fit on the rear of a E30? What would be the best offset on a 9" rim for the rear? thanks
MotorsportsR is offline   Reply With Quote
Old 03-27-2010, 10:37 AM   #829
Yup, that's about perfect. Now what tires you want to run is the question. With 215/40/17s stretched on you won't need to do much if any fender work. If you wanted a "proper" sized tire then you're looking at some extra mods.
Old 03-27-2010, 10:59 AM   #830
MotorsportsR
Thanks! Would you run 17x8 +20 or 17x8 +25 in the front?
Old 03-27-2010, 11:54 AM   #831
+25 one would have a nice stance with the rear 17x9. And it's easier to add a 5mm spacer than regret buying a too-low offset.
Old 04-14-2010, 09:30 AM   #832
gervs
gervs's Avatar
I have a set of 17X7 wheels from my nissan in the shed, 42 offset. I'm just curious if i can make these work at all?
gervs is offline   Reply With Quote
Old 04-15-2010, 08:39 AM   #833
Most 4-bolt Nissans were 4x114.3, so they'd only work with adapters. Not exactly cost-efficient.
Old 04-15-2010, 09:07 AM   #834
gervs
gervs's Avatar
oh the rims are 4X100 and 4X114.3 so they have the proper bolt patern.
Old 04-15-2010, 09:09 AM   #835
Ah. 15-20mm spacers all around then.
Old 04-24-2010, 12:04 AM   #836
Groundpilots
I have an 1988 325is
What is the center bore of a stock 325is wheel??
also i am considering a few different rims at the moment
the specs are
ESM-015WH
Size Bolt Pattern Offset Center Bore Lip Size
► 17x7.5 4x100 20 57.1 2.0"
ESM-009SL
► 15x8 4x100 10 57.1 3.0"
ESM-002SL
15x7 4x100 20 57.1 1.0"
16x7.5 4x100 35 73.1 1.5"
im obviously new towards this kind of stuff, so can anybody help me here??
Groundpilots is offline   Reply With Quote
Old 04-24-2010, 09:26 AM   #837
the specs are
ESM-015WH
ESM-009SL
ESM-002SL
57.1mm. Just about all of ESM's stuff will fit E30s without any rings, spacers, or new bolts; I helped them out with fitment quite a bit, and they have a great direct-fit selection now. Every wheel but the last one is E30-specific.
Old 04-27-2010, 07:27 AM   #838
krazylegz1485
Time for another newb question. These are the specs for the wheel:
Sizing and Specifications
Rim Diameter: 17 inches
Rim Width: 7 inches
Bolt Pattern (Number of Holes): 4
Bolt Pattern (Pitch Circle Diameter): 100 millimeters
Offset: 42 millimeters
Hub Bore: 73.10 millimeters
I've got an '86 325e that I'd be trying to put them on. Any chance I'd be in luck? Or what could I do to "make" them work.
Thanks ahead of time!
krazylegz1485 is offline   Reply With Quote
Old 04-27-2010, 03:05 PM   #839
Rim Width: 7 inches
20-25mm spacers all around and 73.1-57.1mm hubcentric rings. 215/40/17 tires.
Old 04-27-2010, 10:22 PM   #840
krazylegz1485
Sweet. So I'm assuming the spacers make up for the offset and the hubcentric rings make up for the massive center bore of the aftermarket wheels. That makes sense. Any suggestions on where to get such things? Thanks again.
As you can see, I joined the forum back in '04 when I got my Bimmer as a college graduation present. I was gungho on fixing it then but for whatever reason I didn't really get anywhere with it. Needless to say, I never posted here until earlier today, thus I might as well just be a newb.
Anywho, I've got a few really good friends, their dad, and his nice shop for encouragement to get this beast running (6-7 years later!) and we've already made some decent progress. If I were to make a thread about my project for pics and updates, what section should I put it in.
And thanks a ton for the help with the wheels!
