Old 05-02-2015, 09:58 PM   #1
325iExecutiv
Burnt Projector Bowls
My headlights are not as bright as they use to be. I changed the headlight lens and it helped a little.
I did some research and found that projector bowls are a common cause for this. Does anybody have suggestions for places to get this fixed locally.....
325iExecutiv is offline   Reply With Quote
Old 05-08-2015, 04:53 PM   #2
Kolo
Not sure about locally, but I just replaced mine with the Retrofitsource package: http://www.theretrofitsource.com/com...l#.VU0iH5P57QQ
Minimal cutting required, works great.
Kolo is offline   Reply With Quote
Old 07-22-2015, 11:59 AM   #3
TFK
Has anyone thought to actually just repair the original ones somehow? I am thinking to do that once i get time to open up mine.
TFK is offline   Reply With Quote
Old 07-23-2015, 01:25 PM   #4
cirrusblau
Are you running halogens or HID?
FYI, HID bulbs don't last forever, they lose brightness over time and also colour shift, causing additional loss in the perceived/useable brightness. I put in a new set of stock bulbs and the difference was astounding. My lights are incredible now.
Old 07-23-2015, 01:33 PM   #5
TFK
Running oem hid, bulbs most likely still from factory, 2002 with 288k on the dial. Ile look into replacing bulbs then.
Old 07-23-2015, 01:46 PM   #6
cirrusblau
These were the best deal I found at the time last year:
http://www.amazon.ca/gp/product/B004...ilpage_o03_s00
It took a while to get them, but it looks like they have them in stock now.
Also got these
http://www.amazon.ca/gp/product/B00B...ilpage_o03_s01
as an upgrade to the highbeams.
Definitely give the new bulbs a shot since even if you do need new bowls, you're still going to need to bulbs if they are in fact the originals.
Old 07-23-2015, 05:35 PM   #7
TFK
awesome, thanks for the info and the links, much appreciated.
