Old 03-04-2015, 05:24 PM   #1
ahab_01
ahab_01's Avatar
Need to borrow a Compression Tester
Anybody have a compression tester that I could borrow. I am trying figure out the state of my engine. Having some issues and thought this would be a good place to look into.
Thanks in advance!
ahab_01 is offline   Reply With Quote
Old 03-04-2015, 09:02 PM   #2
ac_2007
Cruising in Top Gear
ac_2007's Avatar
Grab one from Canadian Tire or Princess Auto.
They're like $20-30, and if you're cheap you can return em
Old 03-05-2015, 09:45 AM   #3
ahab_01
ahab_01's Avatar
Good idea - didn't know they were so cheap!
Old 03-05-2015, 10:24 AM   #4
jabela
Just curious what issues you're having.
www.maisonapothecare.ca
Old 03-06-2015, 01:34 AM   #5
kenmar
CT actually has a tool loan program. You put down a deposit, borrow the tool, bring the tool back, get your deposit back 100%
Old 03-07-2015, 01:34 PM   #6
ghd
Did you get this sorted?
If not, I have one you could use.
ghd is offline   Reply With Quote
Old 03-17-2015, 11:04 PM   #7
ahab_01
ahab_01's Avatar
Jabela - i started having low coolant after the few weeks of super cold weather we had. I likely added 3 or 4 liters of coolant/distilled water and bled the system 3 or 4 times until it finally settled and has been good for the last week or so. I am really not sure where the coolant went as I can't sense anything leaking.
I need to do a cooling system overhaul but wanted ensure my engine was healthy enough to invest money to fix it.
I am meticulous with my maintenance and love my car. most recently, I changed the CCV and related hoses last summer, oil every 7K with GC.
Any ideas? am I correct in wanting to check compression and perhaps a leak down if that doesn't show anything?
Old 03-18-2015, 09:53 AM   #8
Dinanstu
Anything leaking into the car under the mats from the heater core?
Old 03-19-2015, 09:18 AM   #9
kenmar
Interestingly, I had the same mysterious disappearance of coolant during that extremely cold week. I only lost 0.5L of coolant, so not as disconcerting. No loss/leak before or since. Strange. Perhaps it's the water pump seal not sealing very well when deeply frozen?
