Old 04-09-2015, 02:02 PM   #1
mmmdddmmm333
High pitched whinning sound
Hello everyone,
I have a 2001 330ci and I noticed throughout the winter that when the car was cold I could hear a high pitched whiining sound inside the car. It was very high pitched and only lasted for 5 to 10 seconds at a time. Now as the weather is slowly warming up, I've noticed the noise on the outside of the car when the windows are down. I have no idea what makes this noise or if it's common for this model. The only thing I could suspect is a spededomoter cable, but I dont even know if this car has one !!.
Any Help or suggestions to check would be greatly appreciated.
Thanks.
mmmdddmmm333 is offline   Reply With Quote
Old 04-09-2015, 09:02 PM   #2
ghd
I have a high pitched whine from the engine as revs get up a bit in the cold; goes away when I put the clutch in and coast.
I put it down to a pulley bearing, but don't know which one.
Could be belt tensioner or idler are alternator, or something.
Plan to investigate now that it's warmer out for working on the car.
ghd is offline   Reply With Quote
Old 04-10-2015, 01:45 AM   #3
jabela
Yea, pretty sure there's no speedo cable.
If the sound is in the inside, it may be your blower motor/fan.
If it's the outside, it could be one of your pulleys.
It could also be wind whistling
Does it vary with vehicle speed? Engine speed? Gear? Blower fan speed? Does braking affect it?
www.maisonapothecare.ca
Old 04-13-2015, 11:00 AM   #4
mmmdddmmm333
I've already changed the idler, and tensioner pulley as well as the water pump. I guess that leaves the alternator. Also, my blower fan does make some noise but its a different noise altogether. The whinning does go away at higher revs and then comes back when I shift and and the revs come down a bit. As soon as it warms up after 5 minutes or so, the noise goes away entirely for the day. It only happens in the morning on first start up or after about 6 hours of not driving.
Thanks for your help.
Old 04-13-2015, 11:22 AM   #5
jabela
Could also be the AC compressor pulley. You could remove the AC belt to see if it goes away.
Old 04-25-2015, 01:29 PM   #6
/Alessandro\
Hellrotted
/Alessandro\'s Avatar
My e36 winter beater had this problem turned out to be the alternator
Bleeds Imola
/Alessandro\ is offline   Reply With Quote
Old 04-27-2015, 12:24 PM   #7
mmmdddmmm333
It seems like that is the next item to check. Going to mechanic on wednesday this week. Thanks for all your input everyone. Much appreciated.
Old 04-28-2015, 09:43 AM   #8
03Bullet
Judging by your description it could also be a vacuum leak
03Bullet is offline   Reply With Quote
Old 04-28-2015, 08:08 PM   #9
Scape
If whining goes away with clutch down (assuming its a manual), most likely associated with throwout bearing.
Scape is offline   Reply With Quote
Old 05-30-2015, 11:18 PM   #10
Schmederling
Used Alt off a M54
I have a used Alt - if needed just PM me if needed
Schmederling is offline   Reply With Quote
Old 05-30-2015, 11:20 PM   #11
Schmederling
If there was a Vac leak it would have set of a engine light by now - I had the same issue with cracked intake boots upper & lower. Check that those are in good condition as they will fail with age, common problem with the boots
Old 06-15-2015, 03:11 PM   #12
CrowsFeast
Intermediate Tracker
Have you checked your power steering fluid? My old car had a leak and would occasionally whine until I got it fixed.
CrowsFeast is offline   Reply With Quote
Old 06-15-2015, 06:40 PM   #13
Dinanstu
Secondary air pump. It runs on start up; if it's going out it will whine..
Old 06-16-2015, 11:03 AM   #14
Blackedout95
As mentioned above numerous things but cannot tell over the net unfortunately.
I have seen many DISA valves (mine included) whine/whistle when the seal starts to leak Usually heard a bit at idle and coasting or slow driving like when turning a corner or starting to slowly acc. Like someone is whistling or a kettle blowing and then nothing! Again all just guesses.
E46
