Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 01-04-2015, 08:33 PM   #1
jay328i
jay328i's Avatar
Angry really need ews help no crank
OK so the antenna ring on my 99 328i e46 broke where the wires is sooo first i bought a new battery and tried to do the ews delete by crossing the wires like the ews bypass tutorial shows i just got a crank no spark so i figured it was the ecu i seen an ecu from a 97 328i e36 it had the ews delete from trm performance so obviously it didn't work and i wasted 120$ i thought it might be a chip in the ecu but it ended up being flashed so moving on today i bought a used antenna ring off 2001 530i the part number seemed to be the same so i went and picked it up reason i bought it used is because dealerships are closed Sundays and i really need to get the car started soo that also didn't work when i switched everything back and tied the wires together put the new ring on i have full power cause of the new battery but no crank no spark the fuel pump is on i'm seeing there's just no spark any ideas would be appreciated i really need to get my daily driving car running again
jay328i is offline   Reply With Quote
Old 01-04-2015, 09:01 PM   #2
Does it click when you try to crank?
Old 01-04-2015, 09:13 PM   #3
jay328i
jay328i's Avatar
Yes it does but I turn the power on off the ignition switch
Old 04-09-2015, 07:15 PM   #4
Scape
Check for power at the starter?
Scape is offline   Reply With Quote
Old 04-09-2015, 11:36 PM   #5
Why didn't you replace the ring right from the start!? Would have saved a lot of time and $$$$, as you can tell....By now who knows what is gone/blown/burned. Or it might need the EWS/ECU/key re-aligned (easy job for any BMW shop). Or just buy a matching set.
Old 04-28-2015, 09:42 AM   #6
03Bullet
Sounds like its time to visit a shop.
03Bullet is offline   Reply With Quote
