Old 02-10-2018, 01:22 AM   #1
lockeed
lockeed's Avatar
Anyone used the Foxwell NT630 Scan tool to reset their ABS module?
I received my Foxwell NT630 and I replaced my faulty ABS module on my E39 M5. I plugged the programmer and wanted to re-calibrate/reprogram the new module so finally turn off the traction control light in the cluster.
I did what I though, erased the codes etc... and but light is still there, I was wondering if any of you can shed some light on the actual reset procedure/programming for a new module.
_________________________
E90 M3 6MT - Apline white
E46 M3 6MT - Titanium Silver
E39 M5 6MT - Titanium Silver
W211 E55 AMG - Silver
lockeed is offline   Reply With Quote
Old 02-11-2018, 11:52 AM   #2
MANDD
Autobahn East
This unit will not "code" an ABS module. Typically the ABS/DSC module must be "coded" to the vehicle.
What faults did you have before replacement of the module?
What faults do you have now with the replacement module?
Mark.
Old 02-11-2018, 10:38 PM   #3
lockeed
lockeed's Avatar
Now it says "no communication between etc....) don't remember the exact words, but from what I gathered from a friend and another forum, it just needs to be coded using NCS... I had to order a cable so when it gets here, I'll to the coding procedure and it should solve the problem...
