Go Back   maXbimmer Forums > maXimum Tech > X series
Old 07-10-2017, 02:20 PM   #1
Markx3
E83 rear diff.
Rear diff on my 07 X3 is failing. Oil and water - fine in the fall when oil was changed. Drained the mix out, some metal along with it and refilled. Somewhat noisy and clunky but drivable for now. Can't find the 7 bolt 4.44 ratio that I need. My question is; will an 8 bolt with the same ratio fit? Thanks.
Markx3 is offline   Reply With Quote
Old 07-11-2017, 07:42 PM   #2
Markx3
The good folks in the parts dept. at Policaro BMW had the answer. The 8 bolt is from the SI so apparently it won't fit.
