Old 10-22-2003, 06:01 PM   #1
greekthang
greekthang's Avatar
Angry Need new rear trailings arms for cheap
Hey guy,
Went to my mechanic yesterday and he quote me $580 each trailing arm and obviously I need 2 of them and that price included the core charge. Anyone out the get them for cheap. can afford that cash right now. Please let me know.
Its all about rolling in the X5 !!!
greekthang is offline   Reply With Quote
Old 10-23-2003, 04:50 PM   #2
greekthang
greekthang's Avatar
Can anyone please help me out here.
thanks
Old 10-23-2003, 07:08 PM   #3
KIRASIR
Your Nightmare
KIRASIR's Avatar
Why on Earth do you need trailing arms for a 96 bimmer???!?!?!?
What's wrong with the ones you have now?
SL
thanks
Old 10-23-2003, 10:13 PM   #4
thinair
moderationistismingly
thinair's Avatar
Yeah, they're not exactly a wear item, are they both bent?
Old 10-24-2003, 12:38 PM   #5
greekthang
greekthang's Avatar
Hey guys
Its not that they are bent and I know they are not a wear item but I am getting this thud noise from the rear end still. I changed my cv joints and that took care of some of the problem but it the thud noise is still there after I let of the accelerator to shift (anything above 4000rpm). I went to my mechanice and when the driveshaft rotates a bit the rear trainling arms are suppose to move at the same time. Well the trailing arms don't move at the same time. there is alot of play. My mechanic told me that the trailing arms have a compress hard plastic and like any plastic it wears done. It has been doing this thud noise for quite a while now but just recently its getting bad. Thats why I need to replace them. They also looked at the rear subframes and they are fine.
Please help guys
Old 10-24-2003, 03:27 PM   #6
R_JAY
Has the world for ransom
Are you saying the trailing arm bushings are worn out? If they are then you can just replace those.
Originally Posted by MiroE36 View Post
and on a side note, why such a massive vagina flex
R_JAY is offline   Reply With Quote
Old 10-24-2003, 04:33 PM   #7
greekthang
greekthang's Avatar
I don't know anymore now. this is what my mechanic told me and now I am confused. Shit
Old 10-24-2003, 05:00 PM   #8
R_JAY
I would say replace the trailing arm bushings cause they are known to wear out alot on the E36. Charlie did mine in the summer and it wasn't expensive at all.
Old 10-24-2003, 06:51 PM   #9
greekthang
greekthang's Avatar
I don't know what to believe. My mechanic told me that the trailing arms are loose and she showed me by trying to rotate the trainling arm and you could see the amount of play. Maybe its the bushings. Shit now I am confused. Any experts out there that can shed some light on this not that I don't appreaciate the help R_JAY. Before you changed the bushings did u hear a thud noise like that coming from your rear end ??
Old 10-24-2003, 07:04 PM   #10
KIRASIR
Your Nightmare
KIRASIR's Avatar
If I were you, I'd go to a different mechanic for a second opinion, since your mechanic doesn't seem to be very competent when it comes to bimmers.
On a side note, I know it's too late already but CV joints don't usually produce a "thud" like noise when they go bad. They tend to loudly "click", and usually only when you step on the gas pedal. Also with bimmers they fail very rarely.
It's probably either:
1) Differential carrier bushings
2) Sub frame carrier bushings
3) Trailing arm bushings
All of the bushings above can be replaced.
SL
Old 10-24-2003, 07:07 PM   #11
KIRASIR
Your Nightmare
KIRASIR's Avatar
Also it could be something as simple as a loose muffler hanger .
SL
Old 10-24-2003, 07:31 PM   #12
greekthang
greekthang's Avatar
SL
Subframe he check and said they where o.k. its either 1 or 3 but there is no chance that the entire trainling arm is done for ??
definately no a loose exhaust hander though. already replaced both before. This is a thud noise as soon as i let off the accelerator to shift for that split second
Old 10-24-2003, 10:04 PM   #13
thinair
thinair's Avatar
The trailing arm is held there by bushings, the main one on the front, the lower rear which attaches to the camber aduster, and the upper rear one that attaches to the arm that the spring is on.
Old 10-25-2003, 06:05 AM   #14
greekthang
greekthang's Avatar
Maybe we aren't talking about the same thing. See one side of the arms is attached to the diff and the other to the wheel to make them spin
Old 10-25-2003, 08:18 PM   #15
KIRASIR
Your Nightmare
KIRASIR's Avatar
What you are talking about it called a half-shaft. There are two CV joints per half-shaft and 4 in total. The only thing that can make noise is a CV joint when it develops a play but as I said earlier CV joints tend to loudly "click" and not "thud". Take your car to Charlie(Bimmersport) for a second opinion.
SL
