Old 02-13-2007, 05:41 PM   #1
Bimmer4ever
Do I need intercooler for super charge?
Hey guys I just want to know do I need to buy intercooler for super charging? and if I do what job does this thing do ? thanks alot!
Bimmer4ever is offline   Reply With Quote
Old 02-13-2007, 06:08 PM   #2
SickFinga
SickFinga's Avatar
Do you need it? Depends on how much boost you are running.
Is it recomemneded? YES.
What it does?
It lowers temperature of the air going into your engine from your supercharger.
Cooler air = denser air = more air = more power.
It also allows you to run more boost before your engine explodes. Why? No idea
Old 02-13-2007, 06:40 PM   #3
jeffrie
Addict
jeffrie's Avatar
You do not need an intercooler till you start to pass about 8PSI with the SC approach.
To add to what Sickfinga said, as air is compressed it generates heat and becomes hotter. As your piston compresses air on the compression stroke as it would normaly do, the air/fuel mixture raised temp as it's compressed but within spec to what it was desighned for, add the new hotter compressed air into the mix = your alot closer to pre-ignition temps AKA "PING".
Too many of theis and your engine goes BOOM!.
Old 02-13-2007, 08:24 PM   #4
fukenricen
fukenricen's Avatar
how about u worry about an oil cooler first
KEEP IT SIMPLE,KEEP IT JDM
wooooooo woooooooooo
AntiRice
11.0@130mph
fukenricen is offline   Reply With Quote
Old 02-13-2007, 09:15 PM   #5
JMW
Pole busted to boosted.
JMW's Avatar
i dont have either..
my kit doesnt need it stage 1..
stage 2....yes
Official Team BIMMERSPORTAUTOMOTIVE vehicle owner.
support: thanks to. Bimmersport automotive and audio 2 go (ATG motoring)
Originally Posted by junaid
"i saw your car there when i was there a few weeks ago, looks absolutely stunning man. I think i popped a ****ing boner, that paint looks sick
JMW is offline   Reply With Quote
Old 02-13-2007, 10:37 PM   #6
Bimmer4ever
oI SEE.. thank you guys !
Old 03-10-2007, 06:13 PM   #7
modifiedm3
Better off fitting a charge cooler than an Intercooler..
modifiedm3 is offline   Reply With Quote
Old 03-15-2007, 04:35 PM   #8
Jon@Bimmersport
Jon@Bimmersport's Avatar
My thoughts exactly...
AA uses an intercooler, but also the piping is a lot different than a Vortech unit (used on JMW and Stickyfingas). Both of their kits stage 1 form dont use it due to small boost, 6psi and 8psi. Once stage 2 is introduced they both use an aftercooler (cools after the s/c before the throttle body). Superchargers also suffer from "heat soak". The added cooling at any boost level will help your reliability and also the power.
Old 03-15-2007, 04:42 PM   #9
sloveniaboy
sloveniaboy's Avatar
AA superchargers unlike the vortech units, run off their own oil system which include an oil cooler, they are less prone to heat soak
sloveniaboy is offline   Reply With Quote
Old 04-04-2007, 04:07 PM   #10
modifiedm3
Go for a charge cooler. Well worth fitting.
Steve
http://www.modifiedm3.co.uk
Supercharged, Charge cooler, CO2 System, Water injection, PSS9 Suspension, AP Racing Brakes,19's,Lumma CLR bodykit. UUC Short Shift, etc etc
Old 04-04-2007, 09:55 PM   #11
PedroBMW
Hooked on Boost
PedroBMW's Avatar
an intercooler cools between the s/c and TB too, its just a slang term that Air/Air intercoolers are called "intercooler" because technically its an aftercooler. An intercooler presupercharger would do nothing. I think the reason that most supercharger kits use air/water aftercoolers is because of the packaging issue, there just isn't much space.
http://www.foldingtrailers.ca
Old 04-10-2007, 10:18 AM   #12
notjoe
600rwhp here i come
notjoe's Avatar
Send a message via ICQ to notjoe
The compresson of air creates heat which is why i think it's placed after the blower.
notjoe is offline   Reply With Quote
Old 04-10-2007, 11:52 AM   #13
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Another benefit to water to air intercoolers is the reduced length of charge pipe. 12" of charge pipe is much better for throttle response tan 6 feet of charge pipe. Also, I've seen the way AA routes their intercooler lines, can't say I'm all that impessed with the low underslung tube (lowest point on the car) and multiple 90* bends. I'm sure it doesn't affect much or else AA wouldn't do that, but it would be the deal breaker for me.
Old 04-10-2007, 12:18 PM   #14
330DTM
Cinematographer
330DTM's Avatar
Send a message via ICQ to 330DTM Send a message via MSN to 330DTM
With regards to the rotrex setup, the blower takes up less space than the vortech units, so there is more room left over to fit a FMIC, and I quesetion if AA did this mainly due to cutting cost to make the kit affordable. Afterall, I believe water-air intercoolers cost more than the FMICs and there's less of a pressure drop than using a FMIC.
To sum it up, use a water-air intercooler for vortech setups.
-=Slow In Fast Out=-
330DTM is offline   Reply With Quote
Old 04-10-2007, 01:23 PM   #15
Furious
BMW again.
Furious's Avatar
with prices in mind the aftercooler is more expensive but better suited for the vortech system.
