Old 04-02-2017, 12:06 AM   #1
BMWlust
Power Steering Nightmare
Hey guys, I'm new to the BMW world (mostly Mercedes for me), but I picked up a 2001 740iL with the SLS system. Problem is...it blew up. The power steering pump completely blew the pulley out of itself. I recently installed a reman LUK pump and new belts. Ran the car and turned the wheel while pumping the brakes until all the bubbles cleared and the reservoir level stayed idle. Dropped the car, and it made a horrible grinding noise while turning, to which the pump blew the seal at the pulley again. Now, I took the lines off, the reservoir off, the pump off (have another reman coming), and I also noticed the SLS didn't kick in with the new pump. I have a feeling it's the regulator or the lever is snapped. I tested the lines, and they're solid. The reservoir pours high pressure water out so I know the filter isn't clogged. I'm a bit worried something is prematurely blowing the pumps out (or I got a bad rebuild).
Any guesses?
BMWlust is offline   Reply With Quote
Old 04-02-2017, 12:48 AM   #2
Rebuilt parts can be garbage...Make sure you are using the right fluid, not just ATF or PS. I would just delete the SLS at all...Regulator has nothing to do with the pump, it only adjusts the level in the rear, can not blow up the pump.
Most models E30 E36 E46 E90 E92 E93 E28 E24 E34 E39 E60 E61 E32 E38 E65 E66 X3 X5 M3 M5 Z3 Z4 F30 F32 F10 F01
Old 04-02-2017, 03:30 AM   #3
BMWlust
Thanks for the reply man. I was really hoping it was just a garbage pump. Many bad experiences with rebuilt equipment in heavy duty applications, so it's definitely most likely. I unfortunately, couldn't afford a brand new multi-vane pump at this moment so that was the only option. And yeah, unfortunately, for $65 a litre, I've been throwing CHF11S in :/
Now, I would love to delete the SLS. I got a full set of brand new coilovers with the car when I bought it thrown in. Would I just run a normal single stage pump without the hydraulic line for the suspension and cap the existing line?
Old 04-02-2017, 03:39 AM   #4
BMWlust
After some research, figured out I can just attach the return and feed lines together to "trick" the system and keep the pump running smooth
Old 04-02-2017, 08:00 PM   #5
No, the easy way is to cap it off right from the pump, but you need a special bolt...All the other lines get taken off.
Old 04-02-2017, 08:49 PM   #6
BMWlust
Ah...being as I'm only used to air suspension, may I ask about this special bolt? Haven't had any luck searching
Old 04-03-2017, 12:00 AM   #7
It sits at the end of the cooling line on 95-99 cars with SLS, i'm sure you can get one from a hardware supplier if needed.
Old 04-03-2017, 04:12 AM   #8
BMWlust
So, being as there's no loop in the system, the pressure on it won't bugger the pump up? And I assume the '01 runs the same kinda line? Haven't checked that yet, but I'll take a peek tomorrow and see. I know it's a fairly simple system, but I hear it's extremely delicate and I'm paranoid on blowing a third pump up
Old 04-03-2017, 10:14 AM   #9
No, the line is not the same after 99...
Old 04-03-2017, 06:04 PM   #10
BMWlust
Oh ok. Well I can go with the rerouting of the feed and return lines then I would assume. Either way, this will be a project once I can actually get the power steering pump back in and working haha.
