Old 11-01-2015, 10:52 AM   #31
arturb
Cost me maybe like 600 700 bucks I think. I need to re clear though
instagram: @artur_bastos
My e38 Build
arturb is offline   Reply With Quote
Old 05-18-2016, 06:03 PM   #32
arturb
So i figured its about time i post an update on this thread.....
These events have taken place since last october until now...
Bought an E36 coupe 323is that will become my track car this year or the next provided my E38 project goes well.
Parked the 7 in October. Battery died, sunroof leaked and i have had nothing by electrical nightmares.
The body wasn't in the best shape and i had to replace the gas tank as well because it leaked, so heres my fix to all those problems.
98 740i. Unfortunately it not the 'L' but it is MINT. 170,000km, not a spec of rust on the body, and everything works minus the transmission lol. an internal sensor went and as a result it runs like crap. But the car was cheap.
Also got this...
540i 6 Speed swap kit. Transmission, custom driveshaft, mounts, pedals, clutch, flywheel, pressure plate, etc etc. $1000!!!
I've wanted a 6 speed 7 since i bought my first one and when i saw this deal i couldn't pass it up.
And this is where I'm at right now.
Exhaust, driveshaft, and shifter linkage are all out.
Next i need to figure out how I'm going to delete the auto tranny oil and cooler lines.
If anyone has some info on that i'd appreciate it!
My e38 Build
Old 05-18-2016, 06:35 PM   #33
TSI
Reverse Gear Member
Better that you got the shorty. iL swaps are very hard from what I hear. PM me your email if you like, I'll give you all my stuff from when I did the 540i swap last year. It's a piece of cake if you know basic coding.
TSI is offline   Reply With Quote
Old 05-18-2016, 11:02 PM   #34
All you need to do it take them out! They are not related to anything else, so its a simple delete.
Most models E30 E36 E46 E90 E92 E93 E28 E24 E34 E39 E60 E61 E32 E38 E65 E66 X3 X5 M3 M5 Z3 Z4 F30 F32 F10 F01
Old 05-18-2016, 11:09 PM   #35
The only mechanical difference from I to iL is the rear section of the driveshaft, that is not even modified in the swap...So those are nothing but rumors.
Old 05-19-2016, 09:49 AM   #36
arturb
ill pm you
I've never done any coding. i got the software befor but couldn't get it to work with my old 7. maybe it was the car, maybe it was the cheap software.
it looks simple enough, in theory lol. what can i use to plug the rad?
My e38 Build
Old 05-19-2016, 10:42 PM   #37
ill pm you
It does not have any connection to the rad...So nothing. Just remove the lines/cooler.
Old 05-23-2016, 12:39 AM   #38
arturb
i got the lines out. might just get a plug to match the threads of the hoses and call it a day lol
My e38 Build
Old 05-23-2016, 08:25 PM   #39
arturb
VICTORY!!!
well, at least for this portion of the swap.
what i had to use to get the top bolts lol
now just have to wait for the new seals for the 6 speed transmission to come in and change those. clean it all up, resurface the flywheel and it can go in.
HOWEVER, while i have access to the back of the engine, is there anything i can check for? Leaky seals, and any common problem item?
The wizards at Bimmerheaven if you could shine some light here id appreciate it!
---update---
was suggested to change the crankshaft seal as well as the water jacket right above it.
i looks like the coolant collector is leaking as well....wondering if i should mess with that
My e38 Build
Old 05-23-2016, 09:08 PM   #40
jay01_brown
OBSERVE
sweet build!
Can only imagine what it'll be like to row through 6 gears in this big beast
sub'd
jay01_brown is offline   Reply With Quote
Old 05-24-2016, 01:20 PM   #41
TSI
Reverse Gear Member
Best to do the pipes/hoses now since you have easy access. I personally would also do the RMS and cover, for the same reason.
How did you find the tranny removal? It's all downhill from here...
Old 05-24-2016, 01:58 PM   #42
arturb
You mean replace the rubber hoses? And what's the rms cover?
The removal honestly wasn't bad. Very straight forward hardest part was cracking the driveshaft and guibo bolts loose. Mind you I'm doing all of this on my back with the car on jack stands so I don't have alot of room for leverage. But all in all its not nearly as bad as I thought it would be. Well see about putting the new one in and making the car work lol
Sent from my SM-G900W8 using Tapatalk
My e38 Build
Old 06-03-2016, 07:20 PM   #43
buzzdmonkey
hey art, kindof unrelated but do you still have the iL?
If so could i snag some parts?
'95 black e34 525i 5speed stock, Flipped 3 times. RIP
'94 Orientblau e34 520i which is now m50b25tu.
'97 e38 750il
'87 e30 325i slooooooooooow project
buzzdmonkey is offline   Reply With Quote
Old 06-03-2016, 07:28 PM   #44
TSI
Reverse Gear Member
Sorry, didn't check my email. Yes, the hoses along with the gaskets on the under-manifold pipes. RMS is rear main seal, it's the cover around the seal. Also has its own gasket.
Old 06-03-2016, 07:53 PM   #45
arturb
Yes I do have it. Possiblyyyy. I still need to be able to move the car around my driveway and stuff, for the time bring anyway. What do you need?
My e38 Build
