Go Back   maXbimmer Forums > Classifieds > For Sale > Drivetrain, Engines & Transmissions
Old 10-17-2022, 06:19 PM   #1
Gtfour
Gtfour's Avatar
FS: 2001-2006 BMW E46 M3 S54 engine, DME, wiring, keys, EWS, ?
I am selling a BMW S54B32 engine from an E46 M3. Same engine as Z4M or 2001-2002 Z3M
It cames from a 2005 with 170000km
Engine has been cleaned and never saw winter before.
Oil pan is remove cause I plan to do rod bearings. If you want to do it yourself, I can sell for 500$ less.
Comes with the following parts:
-Engine wiring harness -DME MSS54 -EWS Module & 2 keys -Intake manifold SMG with Bimmerworld silicone intake elbow -VAC Motorsport exhaust hub -starter, water pump, pulleys, AC compressor -Secondary air pump
COMES WITH THE ENGINE STAND!!! Missing an alternator & power steering pump
Maintenance done:
Beisan anti-rattle kit Beisan Vanos seal repair kit Beisan VANOS sealing plate repair kit Beisan exhaust upper chain guide OEM S62 diaphragm hub
-valve adjustement done (see result on pic) -new valve cover gasket -new oil filter housing gasket -new throttle bodies gaskets -new injectors o-rings -new oil pan gasket -new front main seal -new CPV viton o-ring -new coolant pipe o-ring
Perfect for swap in E30, E36, E46, Z3, Z4
I originally bought it for an E30 Coupe S54 project but bought 2 more E46 M3 lately so won?t buy the E30 finally?
Would prefer if someone would come to pick up the engine but can consider doing delivery myselft for extra cash $$$$ in Quebec, Ontario or Maritimes provinces (within 12h of MTL)
Price: 10000$
https://www.kijiji.ca/v-moteurs/vill...ews/1637182700
Gtfour is offline   Reply With Quote
