Old 01-30-2010, 11:27 AM   #1
mahniak
RPM going crazy !
So i was just driving around when my RPM started going crazy, goes from 0 to 7000 back and forth and its been doing this for the last day.
any ideas ?
mahniak is offline   Reply With Quote
Old 01-30-2010, 03:35 PM   #2
nachos23
SweetXi
nachos23's Avatar
throttle position sensor? Any codes?
Old 01-31-2010, 11:23 PM   #3
mahniak
no codes, the engine is running fine no problems at all, its only the gauge that is going crazy it's gonna be fine for a while then i hit a bump and it starts going crazy again until theres another bump
Old 01-31-2010, 11:42 PM   #4
Mad Cow
Pull out the cluster and re-connect all of the connectors. My fuel and temp gauges used to be weird (used to drop to 0 randomly or jump around), then I noticed that they went back to normal for a few seconds if I smacked the dash above them. I pulled the cluster to replace some bulbs and now I haven't had a single issue with them.
Mad Cow is offline   Reply With Quote
Old 02-01-2010, 12:14 AM   #5
mahniak
Yes same thing when i hit it it goes normal a bit, so I guess I'll do what you said once the temperature rises -30 C is a bit too cold to be doing that
Old 02-03-2010, 11:27 PM   #6
aaron320i
Send a message via MSN to aaron320i
Change the cluster. Common problem.
aaron320i is offline   Reply With Quote
