Thread Tools Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
Old 08-14-2016, 01:00 PM   #46
AWD
Originally Posted by M3habib View Post
question regarding "placing plastic under the car"... this is the first iv heard of it, cant you have a big old rug underneath, would that prevent the moisture too?
Iv always used a thick piece of rug under each tire, KEEP IN MIND, if the rug gets wet someway somehow, the moisture will damage your tires more then having it sitting on concrete
would plastic garage tiles do the trick? hehe
AWD is offline   Reply With Quote
Old 10-24-2016, 12:57 PM   #47
guygeo
guygeo's Avatar
For a 135i, is it OK to leave the battery disconnected?
1. I do not have access to an electric plug in the storage area
2. Can it drain all the ECM memory???, so will the car start next spring???
3. Will a small solar (powered by the neon lights of the inside garage) be sufficient to keep the battery charge?
FAST & CHEAP = NOT GOOD
CHEAP & GOOD = NOT FAST
FAST & GOOD = NOT CHEAP
guygeo is offline   Reply With Quote
Old 10-24-2016, 02:47 PM   #48
Yes you can leave it disconnected without any harm. Worst case, you'll loose your radio presets and/or memory seat settings.
Old 10-24-2016, 02:56 PM   #49
guygeo
guygeo's Avatar
Ok, thanks for the fast reply.
Old 10-27-2016, 08:26 AM   #50
tominizer
One other tip. What I use to do with my E30 M3 in my garage was put down a layer of the black roofing tar paper on the concrete floor. Apparent it's a great barrier and it's cheap from Home Depot or similar.
Tom
tominizer is offline   Reply With Quote
Old 10-27-2016, 08:55 AM   #51
guygeo
guygeo's Avatar
Well someone told me that a dead battery can harm one of the main ECM... so I just bought a quick solar charger @ Canadian Tire and installed it on the roof, my car is parked right underneath the lights...Thanks for your input gents.
Old 09-24-2021, 01:23 PM   #52
RTZed
Send a message via ICQ to RTZed Send a message via AIM to RTZed Send a message via Yahoo to RTZed
How much would you guys pay for winter storage for your ski? Assuming that the ski was winterized properly and the fluids were drained from it, would you opt for heated storage or any storage is ok as long as its indoors?
grow your blog - blogexpander
RTZed is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
