Old 12-22-2016, 07:20 AM   #1
haliaman
2002 BMW E39 540i fuel issue
Car starts fine when cold but after warming and a 30 minute or longer shut off it has a long crank time. Once it starts I can restart immediately. Sounds like a fuel problem. Replaced the temperature sensor on the water pump (4 prong) and problem still there.
haliaman is offline   Reply With Quote
Old 12-22-2016, 10:41 AM   #2
TSI
Reverse Gear Member
Sounds a bit like a leaking injector. Do you have any leaks in the engine bay?
TSI is offline   Reply With Quote
Old 12-22-2016, 07:06 PM   #3
haliaman
fuel problem
No smell of fuel. The car is winterized. Canadian tire has a loan a tool. I will get a fuel pressure gauge and check for fuel pressure. Could a faulty fuel regulator cause the same symptoms? No check engine light. Other ideas are the purge valve sensor or fuel check valve. Dont want to random replace parts
Old 12-23-2016, 01:00 AM   #4
TSI
Reverse Gear Member
No, it isn't a fuel pressure issue, unless your car bogs, hesitates or stalls.
If the injectors are leaking, the cylinders will slowly fill with fuel while the car is off. When you go to start it, the engine is more or less flooded. It causes a long crank or even a start, stumble and die condition when the engine hasn't been run in a while. A second start will be perfectly fine. If your injectors have never been serviced there is a good chance the o-rings are leaking.
I had exactly that issue on my 456, it had sat for a long time and the o-rings had dried out, allowing the injectors to leak.
Old 12-23-2016, 01:07 AM   #5
gnome
on the roam
fyi on my 2000 540i, I pulled the fuel rail and took the injectors to Giles @Performance Diesel Injection. He cleaned the injectors, did a before- and after flow test, and replaced the O rings. Long time bimmer advocate, located on Steelcase in Markham.
gnome is offline   Reply With Quote
Old 01-01-2017, 06:20 PM   #6
haliaman
Injector cleaning
Thanks,
What does he charge?
Old 01-07-2017, 05:07 PM   #7
haliaman
Thanks for all you feedback,
One thing I forgot to mention is that the car has no problem starting first thing in the morning outside. However, I was visiting family and parked in a heated parking lot. When I started the car in the morning, I had the same long start that I have mentioned above.
Old 04-30-2017, 07:21 AM   #8
haliaman
Problem fixed-changed fuel filter and regulator
