Old 02-08-2012, 02:13 AM   #1
e30sequel
QUAIFE ERR
320i - any experience/success with performance NOT swap
just acquired 320i - need to do a head job so want to replace with 2.5 head redone and conclude with a small turbo - anyone done this with success, not much love for the 2.0 but it still revs smoother/higher - wanted to capitalize on this - any help appreciated - thanks
Steer with your QUAIFE
e30sequel is offline   Reply With Quote
Old 02-08-2012, 02:23 AM   #2
24V swap>all...
Old 02-08-2012, 04:24 AM   #3
egye30
egye30's Avatar
Originally Posted by Eurostyle View Post
24V swap>all...
you heard the man
Old 02-08-2012, 10:35 AM   #4
Originally Posted by egye30 View Post
you heard the man
As I am finishing up my M50B25TU swap, I am feeling that this was well worth the time.
Old 02-08-2012, 11:44 AM   #5
msinger
M30 swap.
msinger is offline   Reply With Quote
Old 02-09-2012, 02:26 AM   #6
egye30
egye30's Avatar
Originally Posted by msinger View Post
M30 Turbo swap.
Fixed.
Old 02-09-2012, 03:36 AM   #7
El Gato Liso
El Gato Liso's Avatar
i dont think it is...if i can redo, i'd go straight to M52
joking! M50 TU Swap was def worth it...if its cheap! $ Pulls harder from 0km, and once the RPMs are up, especially with VANOS engaged, dumping the gas pedal into WOT, it gooooes!
my fave... 2nd gear @ 4500rpm. and 3rd gear and 5000rpm ! Just make sure your shocks are proper cuz the 24V is heavier than M20!!!! and you will blow your shocks.
R.I.P. E30
Old 02-09-2012, 10:43 AM   #8
I've got Bilstien Sports up front, will those live?
Old 02-09-2012, 07:43 PM   #9
e30sequel
QUAIFE ERR
the swap option is extremely tempting and more trouble free sounding but I will retain the bottom end - I am sincerely interested in the high revv nature of the smaller displacement - and would like to capitalize on this via some boost almost........ 7000rpm limit is more tempting
the swaps will be for future e30s ..... will have a harem of all kinds eventually ..... will post progress as it happens
Old 02-09-2012, 08:12 PM   #10
There is no replacement for displacement!
But realistically, you won't find any difference in regards to the 'nature' of one M20s willingness to rev over another. Sure you may think smaller displacement would want to rev higher, but BMW engineers threw that theory out the window with the S54... Similar design (as far as cylinder spacing and whatnot goes) and yet, with a retardedly long stroke compared to the M20, it manages to spit out a displacement of 3246cc, and it revs to 8k all day.
The biggest limiting factor with revving any original/stock M20 is the top end (ie rocker arms, and to a certain extent, the rest of the valvetrain)...
FWIW, I'm gonna wager a guess that the 320i has a lighter flywheel and maybe that's why you think its more 'willing' to rev.
Old 02-09-2012, 09:22 PM   #11
It's funny how the title of the thread specifically says NOT swap and yet the first 6 posts all say swap lol.
If you put an 885 head on your motor it will lower the compression ratio slightly because the combustion chamber on the 885 head is a few cc larger than on the 731. However if you're planning on going turbo then it's not a big deal as you're going to want to lower the compression anyway.
The stroke on the B20 is so short, I wonder what the limiting factor would be in the bottom end. I'd imagine that if you were to have everything balanced very well, with a set of beefy rockers and stiffer springs you could rev that motor to 8000rpm
Old 02-10-2012, 07:50 PM   #12
e30sequel
QUAIFE ERR
But folks the stock power is produced at 6k with a 6800rpm cutoff - I was on to the idea of 2.5 head because there is one rebuilt/refurb on kijiji that I had in sight........ BUT I am now wondering what the issue will be with regard to head gasket (ie the hg is designed for the 2.5 pistons so will there be a fitment problem??? ..... this is why I was looking for someone who may have done this and addressed this issue or found the answer)
- I was really ready to pull the trigger on the rebuilt head but it came to a screaching halt when these questions started coming up .....I do not want to find out when I have started the job already ......so I will try to research some uk sites to see whats up/feasibility etc ...... and yes if all fails then swappity swap
Old 02-11-2012, 03:11 PM   #13
SamE30e
SamE30e's Avatar
M30..
85 325 - Turbo M52B28.
Old 02-11-2012, 09:07 PM   #14
e30sequel
QUAIFE ERR
yea, was just looking at the frank macalusa write up on e30 but if I went that route it would be because I got a blueprinted one but more likely would go for the e36 323is alum bottom w/single vanos and obd1 top = about 200hp even would be good enough
BUT still interested in retaining 2.0 - there is a bit of info on the b20 and am in the process of digesting ....
Old 02-11-2012, 10:06 PM   #15
msinger
M30 swap - torque is unreal. easy transplant and easily turbo-able after. no brainer.
