Old 05-22-2006, 10:28 PM   #1
Redster
Stuck In The 6th Gear
Redster's Avatar
Some kind of warning system?
So I go to unlock the car today and as soon as I unlock it with the remote my 4 way flashers go on, but not the back, just the front & sides. Turn signals don't work, and the 4way f. button inside isn't flashing, so I can't turn them off. I turn off the car, get out, lock it, unlock it, and everything is fine.
Any idea why would that happen?
"You wanna make moves on the streets? Do not have any attachments, do not have anything in your life you are not willing to walk out on in 30 seconds flat if you spot the heat around the corner."
Redster is offline   Reply With Quote
Old 05-23-2006, 12:25 AM   #2
Redster
Redster's Avatar
Gremlins..
Old 05-23-2006, 12:15 PM   #3
Fre D
FuPa!!
El Cucui
Fre D is offline   Reply With Quote
Old 05-23-2006, 01:20 PM   #4
Does your siren work? That sounds like your alarm went off but your siren is broken
Old 05-23-2006, 03:25 PM   #5
Redster
Redster's Avatar
Siren works, everything works perfectly. When alarm goes on then rear lights start flashing too, right? In this case they don't.
