Go Back   maXbimmer Forums > Specific Regional Areas > Quebec/Gatineau/Ottawa > Quebec/Gatineau/Ottawa Classifieds **NEW** > Automotive
Old 06-04-2009, 08:24 PM   #1
HuD 91gt
Brand new Bilstein PSS & PSS9 Coilover Setup
Brand new Bilstein PSS & PSS9 Coilover Setup.
I took the items out of the packaging for photo's only. All factory packaging/manual's are included.
These kit's will apparently fit the following models.
1992-98 BMW 318i Convertible RWD E36 Chassis
1992-98 BMW 325i Convertible RWD E36 Chassis
1996-98 BMW 328i Convertible RWD E36 Chassis
1992-95 BMW 320i Sedan RWD E36 Chassis
They may fit more, but this is from an application guide I found online.
Bilstein PSS9 Coilover - F4-GM5-8034-H0 - $1250obo
"PSS9 PERFORMANCE SUSPENSION SYSTEM WITH 9 DAMPING ADJUSTMENTS, is the race inspired fully adjustable ride height system featuring mono-tube gas shock absorbers with nine precise damping adjustments. The system includes adjustable mono-tube gas shock absorbers with nine precise compression and rebound settings from comfort to competition, front and rear application specific, progressive rate springs allow accurate adjustment of vehicle ride height and center of gravity for the level of performance you seek."
Bilstein PSS Coilover - F4-HE5-C481-H0 - $900obo
"The Bilstein B14 PSS Suspension allows you to adjust your vehicle’s ride height without the expense of the fully adjustable damping system.
This system features both coilover and standard monotube gas pressure shocks with performance level valving along with application specific, progressive rate coil springs. The PSS system lets you set your car low and tight for optimum performance or back to a more stock like ride height and handling characteristics. Ride height adjustments can be made on the vehicle without removing the suspension. The solid aluminum spring seat and lock nut allows a selective adjustment of the vehicle’s ride height. Spring travel and vehicle body height change, but the spring seat remains pre-loaded throughout the allowable range of adjustment.
Features
Monotube-inverted technology
Performance level handling characteristics
Lowers vehicle ride height 30mm
Threaded body allows additional 20mm of adjustment
Height can be adjusted with system installed"
Please Contact me by email. Colten_s@shaw.ca. I will ship at your expense.
HuD 91gt is offline   Reply With Quote
